Bike Maintenance
Posted: Mon Mar 29, 2010 5:19 pm
by hyosung09
Not being mechanically minded I need help with a rear brake light problem.
I have changed the globe, but it still is not working.
What should i be checking next.
Re: Bike Maintenance
Posted: Mon Mar 29, 2010 8:19 pm
by jaskc78
wire connections and fuses
Posted: Fri Apr 02, 2010 12:43 am
by PeterTrocewicz
I'm assuming that it's the brake light comes on with front lever, but not the rear pedal when you say "rear brake light". Both should work. If it's just the pedal that won't turn on the light, it's probably the switch. It,s ususally right above the pedal, and is pulled on by a spring hooked to the pedal.Sometimes th spring loses its tension, or comes off, or the switch, which sits in a socket on the frame, gets cockeyed and won't come on. The switch has an adjusting nut on it, which makes up for a sacked spying by moving the switch further away from the pedal when you tighten it. Sometimes the switch just stops working. Try these things before worrying about anything else.
