DIY air cleaner
Posted: Sun Sep 05, 2010 1:59 pm
by JamesT
I have a 1988 Honda Elite 50 scooter that I plan to sell. Problem is, the air cleaner foam is starting to degrade, and I need to replace it. Bigger problem is, the part is no longer available. It's just a sheet of quarter inch (or less) foam that's been die cut to fit the housing, and would be easy enough to duplicate. I've seen similar foam used in packaging, but who knows if it would serve the same purpose. Has anyone found a suitable material?
Re: DIY air cleaner
Posted: Sun Sep 05, 2010 4:31 pm
by pchast
Try Air Conditioner Foam?
Re: DIY air cleaner
Posted: Sun Sep 05, 2010 5:44 pm
by JamesT
pchast...
Thanks a lot. I hadn't thought of that. I see that some AC filters are 1/4" thick, and are polyurethane, so they might be a match. Easy enough to see if they withstand oil and gas. Best of all, only five bucks for a lifetime supply.
Re: DIY air cleaner
Posted: Mon Sep 06, 2010 1:01 am
by Gummiente
Re: DIY air cleaner
Posted: Mon Sep 06, 2010 11:46 am
by JamesT
Thanks, Mike. That's a different model Elite (didn't know there was one). Mine's an SA50. A dealer ran a check a couple years ago and said it was discontinued, but I have seen a couple offered on the Internet. They just don't look like mine. Probably too many model changes.
Re: DIY air cleaner
Posted: Mon Sep 06, 2010 11:51 am
by Gummiente
JamesT wrote:Thanks, Mike. That's a different model Elite (didn't know there was one). Mine's an SA50. A dealer ran a check a couple years ago and said it was discontinued, but I have seen a couple offered on the Internet. They just don't look like mine. Probably too many model changes.
Could very well be. If you're going to make your own air filter, though, don't just use ANY foam... you are right in thinking that the material needs to be oil and gas resistant, but you also need to keep in mind that it has to allow enough airflow to make the motor run right but at the same time filter out any damaging particles. With this in mind, your best bet is to go to an auto parts supply store and tell them what you're looking for; they might have the proper foam in stock or could direct you towards an existing foam filter that you can simply cut to size.
Re: DIY air cleaner
Posted: Mon Sep 06, 2010 4:08 pm
by pchast
Yes, that's a better answer.
Re: DIY air cleaner
Posted: Mon Sep 06, 2010 5:34 pm
by BuzZz
You want open cell foam.
You do not want closed cell foam.
If the guy at the counter doesn't know what you're talking about, go someplace else.
Re: DIY air cleaner
Posted: Mon Sep 06, 2010 5:43 pm
by JamesT
Thanks, guys. I'll check around tomorrow.
