Gear Shift Lever adjustment
- Real Name: Gregg Hood
- Years Riding: 1
- My Motorcycle: 2009/Honda/Shadow Spirit 750c2
I would like someone to shed light on how to adjust my gear shift lever on my Honda Spirit 750c2. My boot will hardly fit for shifting.
- Years Riding: 32
Re: Gear Shift Lever adjustment
If you are lucky there should be an adjuster on the shifter to bring the angle of it up or down. If not (as it sounds like you have "big feat" like I do (I have the same issues) is to either:
1. Find lower toe height boots
2. Buy a 2nd gear shift pedal and have a friend/shop cut both, weld them together to get a longer one.
2023 Motorcycle Model Guides
- Johnj
- Real Name: Johnny Strabler
You could pull the shifter off the splines and reinstall it in a different position.
- Years Riding: 32
Thats a really simple and good idea! Sometimes the simplist answers are the best way to go.Johnj wrote:You could pull the shifter off the splines and reinstall it in a different position.
