Will ANY slip-on exhaust work on a wide variety of bikes?
Years Riding: 28
#1 Unread post by totalmotorcycle » Sun Oct 21, 2012 6:47 pm
Slip-on exhausts are not my expertise so I thought I'd throw this out to the community...
Will ANY slip-on exhaust work on a wide variety of bikes (if you could get hardware to mount it) OR are slip-on exhausts very specific to the model of bike? Ie, could you put a slip on from say a Suzuki SV650 to a Triumph Triple? (not that I have said slip on or am buying either bike).
NEW 2020 Motorcycle Model Guides
2019 Motorcycle Model Guides
Re: Will ANY slip-on exhaust work on a wide variety of bikes
#2 Unread post by Wrider » Sun Oct 21, 2012 7:24 pm
The main difference in slipons is how they're mounted. If two bikes mount the same way you can usually pull it off, or if you're up for making your own mounts you can grab whatever slipon you want and use it. Almost all bikes sport/standard/sporty styled bikes have the same exhaust pipe size.
Years Riding: 28
#3 Unread post by totalmotorcycle » Sun Oct 21, 2012 9:36 pm
Wrider wrote:The main difference in slipons is how they're mounted. If two bikes mount the same way you can usually pull it off, or if you're up for making your own mounts you can grab whatever slipon you want and use it. Almost all bikes sport/standard/sporty styled bikes have the same exhaust pipe size.
Interesting stuff; wow, this is a great site to get good advice from eh!
Thanks for the information! :D
#4 Unread post by Wrider » Sun Oct 21, 2012 10:30 pm
Where do you think I learned most of it???
fzrbiker
Real Name: louis
My Motorcycle: 1992/yamaha/fzr
#5 Unread post by fzrbiker » Mon Jul 29, 2013 10:18 pm
I totally agree on this statement, In any case it would be better to get a specific slip on exhaust for a certain bike, less hassle, less cost and time consumed.
