I tightened oil plug too much and crack my case....
- Real Name: John
- Years Riding: 0
- My Motorcycle: 1980 Honda CM 400 T
I have an Honda 1980 cm400t. I am an idiot and tightened the oil plug too much and it cracked the case. Any suggestions? Will JB weld work? Anyone have a link to a cheap used one??
Please Help!
Please Help!
- BRUMBEAR
- Legendary 1000
- Real Name: Dave
- Years Riding: 40
Re: I tightened oil plug too much and crack my case....
a pic would help do you mean the filter case or the drain plug? is it leaking now or just cracked? if leaking drain all the ouil then clean with brake clean get super clean grind a V nock into the crack clean again NO RESIDUE apply epoxy "oil resistant follow direction" let stand for 24 hours put in drain plug proper touque this time fill and PRAYER helps
there aint nothin like it
- Real Name: John
- Years Riding: 0
Thankyou, I believe it is called a lower crank case. It is a mian piece that the plug screws into. All the oil poured out. Forgive my ignorance, but what is a V nock? I will work on pic.
How unheard of would it be to seal drain hole entirely and tip bike over the next time I change the oil like a lawn mower? OK, that is probably impossible for me, but I am poor so I am exploring every option.
- Real Name: John
- Years Riding: 0
Any suggestions on the epoxy?
- Real Name: John
- Years Riding: 0
Serious question: If I didn 't take out plug, but removed my oil filter, wouldn't all the oil run out? Could I seal the oil plug hole entirely and just change the oil by removing the filter?
- Real Name: Ryan
Ok he means a V-Nock like a little v-shaped ditch ground into the metal along the crack with a dremel tool or something similar. Clean it off SUPER CLEAN with brake contact cleaner. Then use JB Weld to fill in the crack up to the drain hole. You will probably want to cover the whole crack even at the drain hole, but it is not possible nor a good idea to fill the drain hole and tip the bike over. After you get it filled in you will want to let it dry for a full 24 hours and then re-thread the drain hole and tighten to spec.
And no the oil sits in the bottom of the engine where the drain plug is, so it won't get but about half of your oil if you do that.
- Real Name: John
- Years Riding: 0
Wow, thankyou. How easy is rethreading a drain hole? How much should I expect to pay if I get a mechanic to do it? What about removing the oil filter rather than flipping the bike? The oil filter is below the drain hole.Wrider wrote:Ok he means a V-Nock like a little v-shaped ditch ground into the metal along the crack with a dremel tool or something similar. Clean it off SUPER CLEAN with brake contact cleaner. Then use JB Weld to fill in the crack up to the drain hole. You will probably want to cover the whole crack even at the drain hole, but it is not possible nor a good idea to fill the drain hole and tip the bike over. After you get it filled in you will want to let it dry for a full 24 hours and then re-thread the drain hole and tighten to spec.
Sorry for so many questions, and thanks in advance to all.
- HYPERR
- Legendary 3000
Are you sure you cracked the case?? How hard did you tighten the bolt?
- Johnj
- Real Name: Johnny Strabler
Dude you really need to get a service manual for your bike.
- NorthernPete
- Real Name: Pete
- Years Riding: 11
pics, and perhaps this should have gone in trouble shooting and maintainance?
2009 GS500F
2009 GS500F
