what did i do?
- Real Name: pickle
- Years Riding: 20
- My Motorcycle: 94/honda/vf750Magna
what did i do?
i disconnected the clutch cable from the cover plate and pulled the drive sprocket cover off of my bike. A '94 vf 750 honda magna. After changing my front sprocket i put the cover on and reconneced the clutch cable. but now the clutch will not engage. I tried removing the cover again and attempted to manualy engage the clutch by poking around with the shaft that the clutch cable moves.. (i am now guessing the lifter rod?) Did i screw the pooch? thank you in advance.. AJ
- Johnj
- Real Name: Johnny Strabler
Re: what did i do?
Hello and welcome to the forum. First I would suggest that you buy or borrow a manual for your model. Sometimes you can find them online.
When you have the cover off, is the clutch engaged? (engaged=engine connected to transmission)
When the cover is on, clutch cable disconnected, is the clutch engaged?
When you connect the clutch cable does it disengage the clutch? I'd say the adjustment of the clutch cable is off.
But I'm working blind, soundless, smelliness, and can't even touch the bike.
- Real Name: Ryan
Re: what did i do?
Sounds to me like JohnJ you didn't reconnect something properly. Like he said get a manual and go from that.
