clutch
- Tricycle Squid
- Real Name: david burcham
- Years Riding: 10
- My Motorcycle: 2000 kawasaki
clutch
i have a 2000 kawasaki vulcan 1500 that runs great until its been run for 40 50 miles snd then i cant idle at red lights because it there is no resistence at all on the clutch lever, could somebody please tell me how to correct this problem as i have quit riding until it is corrected.
- BRUMBEAR
- Legendary 1000
- Real Name: Dave
- Years Riding: 40
Re: clutch
check your resevior if you have a slave cyl or hyd clutch it may be empty
there aint nothin like it
- Real Name: Ryan
Re: clutch
Agreed. Sounds like your clutch needs to be bled.
- Legendary 300
- Real Name: Ron
Re: clutch
If the clutch operates fine for the first 50 miles that suggests to me it's not dry.
Might have air in the system that expands when it gets hot?
Or the slave cylinder gets hot, expands and the piston no longer seals.
I dunno.
(I don't like hydraulic clutches for the long term.)
I dunno.
Ron
Past: 1987 Yamaha XT350
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
- BRUMBEAR
- Legendary 1000
- Real Name: Dave
- Years Riding: 40
Re: clutch
Open the reservoir and have a look there boyO every journey starts with the first step Seriously though the fliud may boil when it gets hot if it's low and you start to loose consistency. Either way the first step is the same.
- storysunfolding
- Years Riding: 22
Re: clutch
Air or water. Remember the fluid is hydroscopic. Flush the lines with new fluid and I bet it goes away. I bet it's a nasty color right now. Remember your fluid should be like your urine- slightly yellow but mostly clear.GS_in_CO wrote:If the clutch operates fine for the first 50 miles that suggests to me it's not dry.
- BRUMBEAR
- Legendary 1000
- Real Name: Dave
- Years Riding: 40
Re: clutch
Well said I replace my fluid, Clutch and brake every year even though I use Dot5.
