I have a 2008 swift punisher - the swing arm has 2 to 3" of play up and down due to the location the swing arm connects to the softail cylinders under the bike there are no rubber bushings. The only so-called bushings are small metal cylinders or (.050 thick of tubing-like pieces) around the shoulder of the bolt. Is this normal? Is the play suppose to be there? Or should I reinstall with polyurethane shock bushings?
Please call me to discuss - David Elkins 352-227-8281 or text and I will call you back. Thank you.
2008 swift punisher swing arm bushing problems
- Legendary 300
- Real Name: Ron
Re: 2008 swift punisher swing arm bushing problems
I had to google what a Swift Punisher is and found ...... you're gonna need some luck with it.
Ron
Past: 1987 Yamaha XT350
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
