no power
dillion
Real Name: cory
My Motorcycle: 03 v star 650 classic
no power
#1 Unread post by dillion »
i have a 2003 v star 650 classic. I rebuilt the carbs and replaced the pick up coil put everything back together. it idles just fine however when i put it gear and take off it has no power at all, i have to give it all the throttle just to stop it from stalling in 1st gear. im lost at this point can anyone help me.
KayBur
Real Name: Kay Burton
Years Riding: 2
My Motorcycle: JAWA 350 OHC Prima
Re: no power
#2 Unread post by KayBur »
Is everything normal with the supply of fuel and its combustion inside the engine? Maybe the problem is just from the side of the engine, it cannot develop revs to switch gears. Maybe somewhere some part of the mechanism is moving away and you just need to tighten the nuts? I think you should have a set of keys and sockets on your farm. I have recently ordered a large set of Neiko 02448A 1/2", which has absolutely everything.
