Bleeding Hydraulic Valves
coffee_brake
#1 Unread post by coffee_brake »
The '92 Nighthawk that I am re-assembling has hydraulic valves and the Clymers says I must bleed them before reinstalling them. Says there's a special tool that will force kerosene into the tappet.
Why? Do I need the special tool? Is there a way around it? Is there a generic tool or a homemade setup?
Jenn S.
AMA #658162
2005 Concours
2001 Vmax
1992 CB750
#2 Unread post by Wrider »
The kerosene is to completely clean them out and flush the old oil out of them.
Not sure why you'd need a special tool on it though. If they're like the others I've seen you can just submerge them in a bath of kerosene and pump them until they're clean, then to the same in oil and reinstall them.
coffee_brake
#3 Unread post by coffee_brake »
Pump them with what? What device do I use to pump the old oil from the tappets?
Jenn S.
AMA #658162
2005 Concours
2001 Vmax
1992 CB750
#4 Unread post by Johnj »
I've used a set of channel-lock pliers.
#5 Unread post by Wrider »
Just pump them by hand by collapsing them and expanding them repeatedly until there's no air or old oil left in them.
coffee_brake
#6 Unread post by coffee_brake »
OK, I didn't even know there was a moving part in that little...thing. I can do this!...I hope.
Jenn S.
AMA #658162
2005 Concours
2001 Vmax
1992 CB750
#7 Unread post by Wrider »
you can do it! We've got confidence in you!
Cof-fee Brake!
Cof-fee Brake!
Cof-fee Brake!
Cof-fee Brake!
Cof-fee Brake!
:laughing:
coffee_brake
#8 Unread post by coffee_brake »
:bag:
Jenn S.
AMA #658162
2005 Concours
2001 Vmax
1992 CB750
