Electronic Ignition Kits
Fargo360
My Motorcycle: 1998 Honda VTR1000 SuperHawk 996
#1 Unread post by Fargo360 »
Has anyone retrofitted a points bike with one of these aftermarket ignition kits? I've been told that one of these would breathe new life into my old bike, but I'm just a little bit skeptical about putting something my bike wasn't designed with. If these kits are the cats meow though, maybe I'll give one a shot.
1976 Honda CBR360R/T
#2 Unread post by Johnj »
I've installed pointless ignition systems on a couple of older Sportsters and a 650 Triumph or two. They always worked and made tune ups a lot easier. Have you tried the relay power to the coil mod as discussed in the other post?
Big B
#3 Unread post by Big B »
i've put several on Indian's when i worked at the dealership, cured a lot of problems, and never had one come back bad.
Fun for the whole Family!
HYPERR
#4 Unread post by HYPERR »
Yeah I would do it. It's almost amazing those things(points) even work at all....especially in those old V8s with the points, condensor, and rotor! :shock:
Fargo360
#5 Unread post by Fargo360 »
I'm building that coil kit right now and plan on putting it on this week. I was talking to my uncle who is an electrical engineer and he said I should look at putting an electronic ignition kit in. That's how I got on the subject. But they are like $175-200, and the coil kit was 20. So I'm going to do the coil kit for now and in the future when I have $200 to throw down I'll get one, maybe next year or so. I have a $20 a month allowance for my bike (otherwise I'd buy everything I see) so I should have the money for one saved up by next spring.
Fargo360
#6 Unread post by Fargo360 »
Um...if I get one of these kits in the future, do I have to "undo" this coil mod?
#7 Unread post by Johnj »
No you wouldn't have to undo the coil power mod.
Fargo360
#8 Unread post by Fargo360 »
So I installed the coil mod last night. I haven't fired the bike up yet because I took the pipes off to change the rear tire. But when I go to run it, if I did it wrong...what's going to happen?
#9 Unread post by Johnj »
It's going to let the coils do their job
What your doing is using the weakened voltage in the bikes OEM wiring to the coil to operate a relay that that connects a new, direct power source to the coils.
My book shows a blue wire and a white wire from the coils that connect to a blue/white wire. Use the blue/white wire to power the relay.
PMs are ok.
