Need help with electrical: Suzuki GS500F 2007 headlight on GS500E 1992
Pierce
Real Name: James Pierce
My Motorcycle: Suzuki
#1 Unread post by Pierce »
This is what I have currently:
http://imgur.com/a/WAcLK
The bulb says 12V 5W
This is not safe to drive at night.
I have also this:
http://imgur.com/a/bfIYh
It's from GS500F 2007.
I'm going for this kind of look:
I'd appreciate any tips on how to make it work?
Re: Need help with electrical: Suzuki GS500F 2007 headlight on GS500E 1992
#2 Unread post by dr_bar »
That's the only bulb? 5W seems more like a day time driving light. It should be closer to 55W.
What is your current bike model and year?
pchast
#3 Unread post by pchast »
That's not the only bulb. You can see th e headlight bulb above it in the
light assembly.
Pierce
#4 Unread post by Pierce »
Forgive me I wasn't precise enough.
I want to mount the headlight from Suzuki GS500F 2007 on Suzuki GS500E 1992.
I have Suzuki GS500E 1992 (purchased used) motorcycle. I also have a headlight from Suzuki GS500F 2007.
Both bulbs from my Suzuki GS500E 1992 are 12V 5W. Under this link you can see the pictures of the bulb: http://imgur.com/a/WAcLK
I have the headlight (only headlight) from Suzuki GS500F 2007. I want to mount this headlight (2007) onto my bike (1992). Here are the pictures of the headlight from GS500F 2007: http://imgur.com/a/bfIYh
The problem I have is that there is a different connection and I don't know where to start, what cables, what parts do I need, etc.
The 2007 headlight has 3 pin bulbs. I was able to identify the 1992 bulbs as the "ATV" type.
Any help appreciated.
GS_in_CO
Real Name: Ron
#5 Unread post by GS_in_CO »
If you are looking for the recipe of part numbers and steps you might want to find a Suzuki-specific forum and ask there.
A 5W headlight bulb seems unlikely so perhaps the previous owner has already done something hinky to the wiring.
I suspect this isn't a drop-in change but additional wiring can always be added by someone with the knowledge to figure it out and do it. But it'll be some work and some experimentation.
You're going to learn from this experience ;-)
Ron
Past: 1987 Yamaha XT350
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
