Re Jetting Suggestions
imaninja
Real Name: Evan
My Motorcycle: 1986 GPZ 1000 Cafe Racer
Unread post by imaninja » Thu Feb 02, 2017 12:30 pm
Hi everyone! I have a GPZ 900 cafe/street fighter project in which I have swapped in a 1986 GPZ 1000 engine. I've attached some pictures if you're interested!
Anyways, the engine isn't running properly. The exhaust is a custom with duel 2.25 ID glass pack mufflers. The carbs currently have K/N duel pods as show in the attached images.
Due to the modifications to the chassis and battery relocation the stock airbox will not fit. In the spring I may fabricate an aluminum intake manifold that can fit in that space which will flow air "similar" to the stock system.
So here's my 2 questions:
1) What size jets would you suggest for the new exhaust and stock airbox?
2) What size jets would you suggest for the new exhaust and the k/n pod filters?
Thanks in advance!
kawi pods.JPG (44.15 KiB) Viewed 1218 times
imaninja
Real Name: Evan
Re: Re Jetting Suggestions
Unread post by imaninja » Tue Feb 07, 2017 1:15 pm
anyone?
Gummiente
Years Riding: 35
My Motorcycle: '15 HD Road Glide
Unread post by Gummiente » Tue Feb 07, 2017 1:34 pm
You can't just throw out an accurate answer to questions like these, there are far too many variables. Start with two sizes up from stock and make sure to use a sync tool when making adjustments. You should also raise the jet needles a notch or two as well.
:canada: Mike :gummiente:
'15 Road Glide
"If loud pipes really did save lives, imagine what you
could accomplish if you learned how to ride that thing"
Users browsing this forum: No registered users and 35 guests
cron
