Bike only getting power on high rpm
Svajus
Real Name: Svajūnas
My Motorcycle: 2005 Derbi Senda
#1 Unread post by Svajus »
I ride a 2005 derbi senda, it has a 70cc airsal engine and a 12,5 mm carb and it only gets normal power at higher rpm. I can go about 60km/h and it sudently starts to scream and gets up to 80-90km/h ir a few seconds, I know that changing a carburator would fix it but is there anything else I can do?
Miles_Ha11
Real Name: Miles Hall
Years Riding: 3
My Motorcycle: 2016 Ducati Supersport
Re: Bike only getting power on high rpm
#2 Unread post by Miles_Ha11 »
Try to check your fuel filter this is one of the common reasons why you are experiencing this problem.
KayBur
Real Name: Kay Burton
Years Riding: 2
My Motorcycle: JAWA 350 OHC Prima
#3 Unread post by KayBur »
I recommend cleaning the fuel filter and changing the fuel used. If it contaminates motorcycle parts, then it is clearly not suitable for use.
Svajus
Real Name: Svajūnas
#4 Unread post by Svajus »
KayBur wrote: Thu Apr 08, 2021 4:24 am I recommend cleaning the fuel filter and changing the fuel used. If it contaminates motorcycle parts, then it is clearly not suitable for use.
The fuel is good, i mix it up myself, but what does fuel have to do with a bike getting a lot of power at mid rpm?
