Motorcycle Jacket for Hawaii
hey I live in hawaii, and regarding heat i will just say that I would feel more than comfortable riding without a shirt on around here. Of course im concerned about safety, and I would like a jacket that is very breathable yet protective at the same time.
I am basically looking for a good jacket for relatively hot weather, I don't want to get on my motorcycle and be in a sweaty mess after each ride. Thank you very much for any help in advance.
and I almost forgot to mention, I would like it if it was (somewhat) waterproof as well, seeing that it rains around here sometimes.
- Grey Thumper
- Legendary 1000
- Real Name: Dino
- Years Riding: 9
I live in a pretty hot and humid place too, and I'm thinking of getting one of these http://motoport.blogspot.com/
Anyway, I'd still recommend a mesh jacket over just a t-shirt for reasons aside from protection. A mesh jacket keeps the sweat on you longer without trapping it in, so you benefit more from evaporative cooling. Plus, the mesh helps keep you from getting sunburned.
- Gadjet
- Real Name: Owen Clark
- Years Riding: 19
- My Motorcycle: 2020 KTM 200 Duke
- Contact:
I can attest that this is incorrect. The sun still gets through the mesh to your skin. I found that out when I went to Arizona and Mexico two years ago. T-shirt and mesh jacket and I still got a bit burned on my arms.Grey Thumper wrote: Plus, the mesh helps keep you from getting sunburned.
1983 Suzuki GS650GL (sold)
2005 Kawasaki KLR 650 (sold)
2020 KTM 200 Duke
IBA#20953
IG: @greenmanwc
2020 KTM 200 Duke
IBA#20953
IG: @greenmanwc
ahhhh! And your from michigan!!!ofblong wrote:I wear a teknic jacket that has a removable liner but it also has "zippers" to allow air flow into my body. Still gets hot when your not moving though.
Gosh are motorcycle jackets really that bad? I was wondering why I saw so many ppl riding around here with nothing but an aloha shirt and jeans.
Does mesh give you adequate protection?
thanks for all the help so far guys!!!
- ofblong
- Legendary 2500
- Real Name: Ben
true it only gets to 90 degrees with 100% humidty about 2-3 weeks of the summer up here. Occasionaly we get over 100 degrees with 100% humidity but that would be like 3 summers ago where we had 30 90 upper 90 degree days and like 12 100 degree days with close to 100% humidity. I would MUCH rather have dry heat like Texas has lol.lukem5 wrote:ahhhh! And your from michigan!!!ofblong wrote:I wear a teknic jacket that has a removable liner but it also has "zippers" to allow air flow into my body. Still gets hot when your not moving though.
96' Honda Shadow Deluxe VLX
- sapaul
- Years Riding: 90
Gets hot in SA too. I wear a lycra sun block long sleeved shirt under my leathers and this just wicks the moisture away.
I would rather sweat than bleed.
www.thinkbike.co.za
www.thinkbike.co.za
