About this oil
Wincolt
Real Name: Bill W.
About this oil
#1 Unread post by Wincolt » Fri Nov 12, 2010 5:30 pm
Hello I pick this oil up today and was wondering if it is any good to use I have a 1974 yamaha gtmx 80cc 2 cylinder the oil is synthetic sae 10w-30 lucas high performance motorcycle oil thanks.
Years Riding: 38
Re: About this oil
#2 Unread post by BuzZz » Fri Nov 12, 2010 6:55 pm
Use it where? In the trans.... should be OK. Mixed with the fuel.... not so much. You want 2 stroke pre-mix oil for that.
HYPERR
Re: About this oil
#3 Unread post by HYPERR » Fri Nov 12, 2010 8:47 pm
There never seems to be a general consensus when it comes to the tranny oil for a 2 stroke bike w/ a wet clutch. People swear by on everything from straight 30 to 10W40 to 80/90 gear oil.
Wincolt
Real Name: Bill W.
Re: About this oil
#4 Unread post by Wincolt » Fri Nov 12, 2010 10:46 pm
Yep I will be using it in the trans part thanks
