"If you've ever tried to remove fuel from a gas tank with a hot, spark-prone hair dryer.....you might be a redneck"gerpena wrote: after that i will try blowing on one end with a hair dryer, for about an hour to get rid of the vapors.
Draining a Gas Tank Problem… Drawing Included
- High_Side
- Years Riding: 48
Then we'll talk about tank rust in a couple of weeks.....Crydee wrote:dilute it with water and flush it out
Visit:
High_Side's Trips and Pics
- Sev
"If you've ever had your nipple bitten off by a beaver... you might be a redneck.ZooTech wrote:"If you've ever tried to remove fuel from a gas tank with a hot, spark-prone hair dryer.....you might be a redneck"gerpena wrote: after that i will try blowing on one end with a hair dryer, for about an hour to get rid of the vapors.
- Sev
You win, your neck is redder then mine.
Which one do you have? I've got a copy of the Blue Collar Comedy Tour Rides again.
- Nibblet99
naked flames work well for getting rid of petrol, but it may be worth putting some fire retardant gel on your eyebrows first
Sorry, couldn't resist
