Question about brakes
xRider
Real Name: Marc
My Motorcycle: Motomia Enzo 150cc
#1 Unread post by xRider » Fri Sep 23, 2011 11:41 am
Why isn't the back brake connected to the brake light on my bike? Only the front brake activates the brake light.
I almost only use the back brake because I find using the front brake uncomfortable.
Dream Bike
2006 Ducati Sport 1000
Re: Question about brakes
#2 Unread post by dr_bar » Fri Sep 23, 2011 12:38 pm
First off, practice braking with both brakes as the majority of your braking power comes from the front brake.
There should be a switch attached to the rear brake linkage somewhere, and it may be out of adjustment, broken or need a spring to connect it to the linkage. Go looking and I'm sure you'll find it. Theoretically, an easy fix and I'm sure if I'm mistaken or there's another possibility, Wrider or his fellow compadres will chime in...
#3 Unread post by Wrider » Fri Sep 23, 2011 3:34 pm
dr_bar wrote:First off, practice braking with both brakes as the majority of your braking power comes from the front brake.
That's exactly what I was thinking. :D
Usually there's a spring attached to the rear brake lever that pulls on a switch mounted behind your footpeg, and that can come off or break.
And definitely practice with your front brake. My sister was using her rear almost exclusively, and when I finally broke her of the habit she was shocked at how much more braking power she had.
xRider
Real Name: Marc
#4 Unread post by xRider » Sat Sep 24, 2011 12:27 pm
Thanks, I checked and saw that the spring was only connected to the brake cable and not to the back brake. So I just connected it and adjusted it and now its working fine.
Dream Bike
BRUMBEAR
Real Name: Dave
Years Riding: 40
#5 Unread post by BRUMBEAR » Sun Sep 25, 2011 12:18 pm
Keep using the back brake to much, make reservations at the hospital there is a reason the front brake radios is more than triple the size of the rear
there aint nothin like it
#6 Unread post by Wrider » Sun Sep 25, 2011 12:33 pm
BRUMBEAR wrote: there is a reason the front brake radius is more than triple the size of the rear
Yup, when you brake, the weight of the motorcycle transfers to the front wheel, giving it a whole lot more grip.
Grey Thumper
Real Name: Dino
#7 Unread post by Grey Thumper » Mon Sep 26, 2011 9:39 am
And of course, the same weight transfer means less weight on the rear wheel, and a corresponding decrease in grip. A loss of enough traction makes it more likely that the rear wheel will lock, which basically means the doo doo will soon fly into the oscillating wind-making device.
storysunfolding
Years Riding: 22
#8 Unread post by storysunfolding » Mon Sep 26, 2011 2:22 pm
BRUMBEAR wrote:Keep using the back brake to much, make reservations at the hospital
Which primary control can you use too much without needing the hospital?
My Blog
Grasp life by the handlebars
BRUMBEAR
Real Name: Dave
Years Riding: 40
#9 Unread post by BRUMBEAR » Mon Sep 26, 2011 8:00 pm
Throttle Baby if don't work you were going to the hospital anyway when in doubt GAS IT OUT!!!!!! Just kiddin I wanted to make as strong a point as possible that rear brake as a primary is BAD MEDICINE
storysunfolding
Years Riding: 22
#10 Unread post by storysunfolding » Mon Sep 26, 2011 9:46 pm
Interesting that you picked a track saying convincing someone to stay on the throttle and off the brakes.
Of course, no one has ever used too much throttle
http://www.youtube.com/watch?v=QKsOGFh3Efk
The rear brake remains an important control on a motorcycle. Gives more stopping power for street riding, and you need it to be competitive for track riding. When a rider realizes that they can't use it appropriately, it's time for the rear brake to become their focus in learning.
My Blog
agraebner
Real Name: Aaron
Years Riding: 13
#11 Unread post by agraebner » Tue Sep 27, 2011 9:04 am
The problem was not too much gas, it was too little. If he had given it gas like he meant it there would have been wheel spin and he would have been just fine.......... :laughing: Learning to balance braking is one very important part of riding. If you cannot balance breaking its going to cause you a problem. Learning to utilize both brakes will allow you tighter smoother turns, shorter stopping distances by a LOT, and much more stability.
xRider
Real Name: Marc
#12 Unread post by xRider » Tue Sep 27, 2011 9:11 am
Thanks for the all the input, I have started to use my front brake more now.
Dream Bike
