2012 Triumph Daytona 675 - US Specifications/Technical DetailsHYPERR wrote:what do you mean?madjak30 wrote:ask Honda if they would like their CBR600 to perform as well as a Triumph??
Engine and Transmission
Type Liquid-cooled, 12 valve, DOHC, in-line 3-cylinder
Capacity 675cc
Wet Weight (ready to ride) 185 kg (407 lbs)
Performance (measured at crankshaft to 95/1/EC)
Maximum Power 125PS / 124bhp / 92 kW @ 12600rpm
Maximum Torque 72Nm / 53 ft.lbs @ 11700rpm
2012 Honda CBR600RR - US Specifications
Engine Type: 599cc liquid-cooled inline four-cylinder
Curb Weight*: 410 pounds (CBR600RR)
No Hp rating for the Honda, but it is 118Hp ish...weight is similar (Triumph is 3lbs lighter), but the 6Hp advantage and a torque advantage throughout the rev range...it's just a more refined machine...and I think the Triumph looks and sounds better...personal opinion of course...
But I'm sure you will have a totally different take on it...I'm not a sport bike rider, so I am only going by what is available on a spec sheet...so take it as you will...(I thought the Hp advantage was more...)
Later.
