2015 Ducati Diavel - Coolness Factor = 64.8%
Your Coolness Factor of the 2015 Ducati Diavel is:
View results
Unread post by totalmotorcycle » Fri Apr 04, 2014 8:49 am
2015 Ducati Diavel on the Total Motorcycle Cool Wall
For A LOT MORE photos and information click here: http://www.totalmotorcycle.com/motorcyc ... Diavel.htm
Don't call me a cruiser...
The intoxicating design, with innovative LED headlight, and refined rider comfort of the new Diavel may imply "cruiser," but the brute force of its 162 hp Testastretta engine and its razor sharp handling prove otherwise.
The new Ducati Diavel Make a bold statement
Ducati s latest Diavel introduces many new features to the highly awarded sport cruiser, including a new engine and exhaust system and styling refinements that combine the model s muscular and assertive look with an elegance and sophistication now synonymous with the premium Italian brand. The new Diavel now makes a bold statement and strengthens Ducati s Performance Redefined mantra by using latest technologies to produce super-smooth performance with enhanced comfort and usability.
2015 Ducati Diavel Totalmotorcycle.com Key Features
New for 2015
2015 Diavel new features overview
All Diavel models
- New Testastretta 11 DS engine
- New exhausts system
- Full LED illumination
- New headlamp cover and mounting
- New bar-risers
- New radiator covers
- New seat
- New fuel gauge and side-stand TFT instrumentation icons
Diavel
- Body: Dark Stealth
- Frame: Black
- Wheels: Black
- Silencers: Black
Diavel Carbon
- Colour 1:
o Body: red carbon (gloss red over matte carbon weave)
o Frame: Ducati red
- Colour 2:
o Body: Star White (white over matte carbon weave)
o Frame: Ducati white
- Wheels: Black. Marchesini, forged, turned and milled to expose the natural aluminium
- Silencers: Stainless-steel silver
2015 Ducati Diavel - Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $17,995 USD
Canada MSRP Price: $19,295 CDN
Technical specification
Engine
Type
Testastretta 11° L-Twin, 4 Desmodromically actuated valves per cylinder, liquid cooled
Displacement
1198.4cc
Bore x Stroke
106 x 67.9mm
Compression ratio
12.5:1
Power
119 kW (162 hp) @ 9,250 rpm
Torque
130.5 Nm (96.3 lb-ft) @ 8,000 rpm
Technical data referring to power and torque was measured on an engine test stand at Ducati.
Fuel injection
Electronic fuel injection, elliptical throttle bodies, fully ride-by-wire controlled
Exhaust
Stainless steel muffler with aluminium tips; catalyzer and 2 lambda probes
Transmission
Gearbox
6 speed
Primary drive
Straight cut gears, ratio 1.84:1
Ratio
1=37/15 2=30/17 3=27/20 4=24/22 5=23/24 6=22/25
Final drive
Chain drive; 15 tooth front sprocket, 43 tooth rear sprocket
Clutch
Slipper and self-servo wet multiplate clutch with hydraulic control
Chassis
Frame
Tubular steel Trellis frame
Front suspension
Marzocchi fully adjustable 50 mm usd fork with DLC-treatment
Front wheel
Lightweight alloy, 14-spoke with machined finish 3.50" x 17"
Front Tyre
120/70 ZR 17 Pirelli Diablo Rosso II
Rear suspension
Fully adjustable rear shock with progressive linkage. Remote spring preload adjustment. Single-sided aluminium swingarm
Rear wheel
Lightweight alloy, 14-spoke with machined finish, 8.00" x 17"
Rear tyre
240/45 ZR17 Pirelli Diablo Rosso II
Front wheel travel
120mm (4.7in)
Rear wheel travel
120mm (4.7in)
Front brake
2 x 320 mm semi-floating discs, radially attached Brembo Monobloc 4-piston callipers with ABS as standard equipment
Rear brake
265mm disc, 2-piston floating calliper ABS as standard equipment
Instrumentation
Handlebar mounted instrumentation with LCD display: speed, rpm, time, coolant temp. Warning lights for: Neutral, turn signals, high-beam, rev-limit, DTC intervention, ABS status, oil pressure, fuel reserve. Tank mounted instrumentation with TFT colour display: gear selected, air temp, battery voltage, trips 1 & 2, fuel reserve trip, average and actual fuel consumption and speed, trip time, scheduled maintenance. Full status and/or management of Riding Modes, DTC, RbW and ABS.
Dimensions and weight
Dry weight
210kg (463lb)
Weight data refers to the dry weight of the motorcycle without battery, lubricants and coolants for liquid-cooled models.
Wet weight (KERB)
239kg (527lb)
Kerb weights indicate total bike weight with all operating consumable liquids and a fuel tank filled to 90% of capacity (as per EC standard 93/93).
Seat height
770mm (30.3in)
Wheelbase
1590mm (62.6in)
Rake
28°
Trail
130mm (5.1in)
Fuel tank capacity
17l - (4.5 US gal)
2017 Motorcycle Model Guides
Re: This Week: 2015 Ducati Diavel - Vote Today
Unread post by totalmotorcycle » Fri Apr 04, 2014 8:52 am
Newly released (I had this bike up 2 months ago but it's finally made it to the Cool Wall), the 2015 Diavel is the first 2015 offering from Ducati. What do you think of it and the changes?
Shriker
Years Riding: 37
My Motorcycle: '13 VMax,'98 VTR1000F, '87 XT350
Unread post by Shriker » Fri Apr 04, 2014 9:10 am
Yee Haw.....I am first up......
Voted Cool , down from an Awesome for the original Diavel.....new one , though supposedly improved in many small ways looks less good to my eye with new head light. Comfort improvements hopefully successfull, it really needed a better seat (and seems to have gotten one).
Wrote a review recently about the '13 I rode, LOVED it.......but bought something else.
BRUMBEAR
Real Name: Dave
Years Riding: 40
Unread post by BRUMBEAR » Fri Apr 04, 2014 5:40 pm
I had to go uncool I really like ducati machines for the most part but not this bike I just don't like it it doesn't belong in the Ducati lineup IMO.
there aint nothin like it
ceemes
Real Name: a big secret
Unread post by ceemes » Fri Apr 04, 2014 8:23 pm
I gave it an awesome, mainly because I really like the look of it.
HYPERR
Unread post by HYPERR » Fri Apr 04, 2014 9:38 pm
May be the mfugliest bike sold today. Epic Fail. I have never seen one on the road, actually...does it even sell???
JackoftheGreen
Real Name: Eric
Unread post by JackoftheGreen » Sat Apr 05, 2014 3:48 pm
The heart says Awesome, the head says Fail...
This bike is sorta like that company that will 'name' a star after someone as a gift. It'll put a big smile on your face, but it's ultimately useless. Unless going around in circles at a track twenty minutes from home is your idea of fun. Anywhere else, riding this bike at better than 60% would be a jail-able offense and I'd say good riddance.
Without ANY ability to 'take it with you' on this, going any further than a day trip would be difficult. Maybe if you included a back pack you could possibility pull off an overnighter, but that's about it.
For all that though, it really IS wildly sexy. H.R. Giger couldn't have done a better job on the motor, and the way the tank flows into the saddle and the aggressive cut-out into the rear deck -- just art.
So okay Duc, I'm a sucker for a sharp, modern looking bike. You keep building tilt'a'whirls if you like, but make 'em look like this and I'll hand out a Cool. (-:
Grey Thumper
Real Name: Dino
Unread post by Grey Thumper » Mon Apr 07, 2014 6:34 am
JackoftheGreen wrote:Without ANY ability to 'take it with you' on this, going any further than a day trip would be difficult. Maybe if you included a back pack you could possibility pull off an overnighter, but that's about it.
You can get panniers and a luggage rack for it. http://www.ducati.com/accessories/diave ... ssories.do
40 liters for the panniers isn't much. Maybe add an aftermarket top case or duffel bag. I guess a weekender is doable.
Anyway, as a fairly short guy, I appreciate the Diavel. I've heard the engine is awesome and the bike handles fairly well. The looks are growing on me. I've seen a few on the road, and they're quite attention getting. Still nowhere near what you'd call pretty, especially by Ducati standards. But it's cool enough for me.
montanalifter
Real Name: Bill
Unread post by montanalifter » Mon Apr 07, 2014 5:55 pm
Diavel would be a lot of fun to ride, would be hard on my insurance though. Diavel strada a little more equipped but not much. Definitely a cool.
JackoftheGreen
Real Name: Eric
Unread post by JackoftheGreen » Wed Apr 09, 2014 5:13 pm
Wow, Wednesday already and only 23 votes on a Ducati?
BRUMBEAR
Real Name: Dave
Years Riding: 40
Unread post by BRUMBEAR » Wed Apr 09, 2014 5:34 pm
I am really kind of surprised on this one? You see Nj has very affluent areas where $20K bikes are a dime a dozen and I honestly have never seen one on the road, I freuquently am in NYC area another affluent area Conn and will make runs up to Bear Mountain where if it aint Ducati,they look right down there nose at ya :mrgreen: well ok ya got me there it aint that bad but I still haven't seen one? I guess it doesn't mean it isn't cool though so there ya have it SURPRISE :D
Years Riding: 41
Unread post by High_Side » Thu Apr 10, 2014 7:37 am
There are actually quite a few running around Calgary, and I know one owner who loves his.I like the concept of the bike, but the seat is basically a notch that locks you in, and makes the bike a no-go for me. Overall however, its cool at least for being unique and apparently quite competent as well.
HYPERR
Unread post by HYPERR » Thu Apr 10, 2014 7:39 pm
BRUMBEAR wrote:I am really kind of surprised on this one? You see Nj has very affluent areas where $20K bikes are a dime a dozen and I honestly have never seen one on the road, I freuquently am in NYC area another affluent area Conn and will make runs up to Bear Mountain where if it aint Ducati,they look right down there nose at ya :mrgreen: well ok ya got me there it aint that bad but I still haven't seen one? I guess it doesn't mean it isn't cool though so there ya have it SURPRISE :D
I live in Fairfield County, CT which is one of the most affluent areas in the US, and I have never seen one on the road either! Not one! I see sh!t load of Ducatis and have even seen few Desmosedicis.
Unread post by totalmotorcycle » Fri Apr 11, 2014 11:58 am
I went with: fail
It's an interesting concept idea, but (to me) it's like D&G designing a sledgehammer. Close up, parts of the bike look really neat, but as a whole, it's just "crude" to what Ducati can do. The engine is awesome, and they have the same engine in the Multistrada (off the top of my head), but as suggested the Diavel's locked in riding position isn't as comfortable.
I'm surprised as well it continues to sell and is offered. When it first came out I thought it was a mistake, not it's just an oddity. If I was looking at the Diavel I think I'd consider a SuperDuke, which is a more purpose built bike.
Unread post by totalmotorcycle » Fri Apr 11, 2014 12:14 pm
2015 Ducati Diavel - Coolness Factor = 59.8%
Featured: April 4th, 2014 - April 11th, 2014
Motorcycle Cool Wall discussion: viewtopic.php?f=61&t=49093
Total Motorcycle model page: http://www.totalmotorcycle.com/motorcyc ... Diavel.htm
Awesome (3 points) 32% 32% [ 11 ]
Cool (2 points) 35% 35% [ 12 ]
Uncool (1 point) 12% 12% [ 4 ]
Fail (0 point) 21% 21% [ 7 ]
Total votes : 34
= a Coolwall Factor of 59.8%
NOTES: A very interesting bike offered up by Ducati that many feel is the "red-headed stepchild in the attic". Did Ducati do enough to "revise it" and re-define it? Probably not. Is it a bad bike? Not really, it's purpose is a little muddy, it's design isn't really Ducati. The one thing that makes it cool is that it is different and the non-Ducati-Ducati.
Next 2014 TMW Cool Wall bike is now up for voting on, have fun!!
Kenny Roberts
Real Name: Kenny Roberts
My Motorcycle: Yamaha RZ 500
Unread post by Kenny Roberts » Sat Sep 12, 2015 1:24 pm
Looks like Ducati's version of a Yamaha V-Max.
faded sun
Years Riding: 42
Unread post by faded sun » Mon Sep 21, 2015 10:12 pm
Kenny Roberts wrote:Looks like Ducati's version of a Yamaha V-Max.
You nailed it! I was trying to think what it was reminding me of.
Just doesn't look as comfy as the Max.
Jock
jstark47
Years Riding: 13
Unread post by jstark47 » Thu Sep 24, 2015 8:39 pm
faded sun wrote:Just doesn't look as comfy as the Max.
Haven't ridden one, but have sat on them at motorcycle shows. It felt very comfortable. Appearances are deceiving.
Users browsing this forum: markdcoco, montanalifter and 117 guests
cron
