2017 Yamaha SCR950 - Coolness Factor = 68.9%
Your Coolness Factor of the 2017 Yamaha SCR950 Review is:
View results
Unread post by totalmotorcycle » Fri Jun 17, 2016 12:01 pm
2017 Yamaha SCR950 Review on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... SCR950.htm
All New Vintage... 2017 Yamaha SCR950
All-new SCR950 combines vintage, scrambler styling with modern engineering. Potent 942cc V-Twin, spoke wheels, high rear fender.
Conquer Road
For riders who are looking for a rugged vintage design but want the reliability of today's motorcycles, look no further than the all-new SCR950. With distinct scrambler style, modern technology, and a pulsating 942 cc V-twin, the SCR950 blurs the line between past and present.
/// Power
Powering the SCR950 is Yamaha's reliable 942 cc, air-cooled, 4-valves per cylinder, 60° V-twin engine which produces excellent torque and power delivery across a wide RPM range.
/// Style
The SCR950 comes fitted with a flangeless teardrop tank, vintage graphics with matching number plates, wide handlebars with crossbar, and block pattern tires mounted on lightweight aluminum spoked wheels to give that distinct scrambler character.
2017 Yamaha SCR950 http://www.Totalmotorcycle.com Features and Benefits
/// Engine
• Blacked out, 942cc, air-cooled, SOHC, 4-valves per cylinder, fuel injected, 60° V-twin power plant pumps out impressive power & torque. Maximum torque is reached at 3,000 rpms.
• SOHC, pent-roof, 4-valve cylinder heads.
• 4-valve design optimizes breathing efficiency & overall engine performance at all rpms
• 31.5 mm intake & 28 mm exhaust valves use friction reducing single valve springs
• compact pent roof combustion chamber design & optimized squish area forces the fuel / air mixture toward the centre of the combustion chamber for more complete combustion & excellent power with reduced emissions
• 25,000 km valve adjustment intervals
• Specially designed roller rockers activate the valves.
• Y shaped roller rocker arms allows a greater amount of valve lift without causing excessive camshaft wear & friction
• slipper portion of the rocker arm utilizes a needle bearing for reduced camshaft wear & reduced sliding resistance (friction)
• No fuss, traditional air-cooled engine design.
• cylinders have a tapered "V" appearance to highlight the V-twin engine design
• cooling fins have been optimized for excellent cooling even in stop & go traffic
• easier maintenance
• Automatic cam chain tensioners reduce mechanical noise & simplify
maintenance. • "Liner-less", ceramic composite-plated cylinder bores.
• ceramic coating sprayed directly on the aluminum blocks, eliminating the liners & reducing weight
• excellent heat dissipation for consistent power delivery
• ceramic coating enhances the thin film of oil between the cylinder & piston, reducing friction & increasing power
• Flat top, lightweight forged aluminum pistons.
• less reciprocating mass for fast engine response
• reduced mechanical vibration for excellent reliability
• Single pin style crankshaft.
• design accentuates V-twin engine character, pulse feel & sound
• Crankcases feature a "Tri-Axis" layout for the crank, main & drive axles.
• creates a more compact & shorter engine front to back
• shorter engine allows for optimum engine placement in the "sweet spot" of frame for desired weight distribution & great handling
• Wet sump lubrication system with easy access, spin on oil filter & drain plug for easy oil changes.
• Classic side mounted 2.3 litre air box houses an easy access, a high-flow viscous paper-type filter.
• "Closed loop", dual bore, 35 mm throttle body fuel injection system with linear throttle response for easy riding.
• system uses throttle position sensor (TPS) to help optimize intake air flow & power
• ISC or idle speed controller ensures a steady idle
• 4 - hole injectors optimize fuel atomization & feature a dual spray pattern for more complete combustion chamber filling
• "closed loop system" uses an oxygen sensor to "sniff" spent exhaust & automatically adjust the fuel / air ratio for reduced emissions
• oxygen sensor is located before the mufflers, so the use of aftermarket "slip-on" mufflers will not affect the closed loop system
• fuel injection benefits include; excellent throttle response, choke-free starting, steady idling during warm up, excellent fuel economy & reduced emissions
• Smooth-shifting, 5-speed transmission.
• optimized gear ratios match engine power for strong acceleration
• 5th gear offers reduced engine rpms at highway speeds
• clutch is an "outer pull" design for light, easy lever effort
• Narrow design belt drive with carbon fibre cords.
• narrow 21 mm wide belt design
• cleaner & quieter than chain drive... no messy chain splatter
• low maintenance... no regular adjustments or lubrication required
• belt drive system simplifies customization
• Maintenance-free transistor controlled ignition (TCI).
• produces a strong spark for fast starts
• provides precise ignition timing / mapping for optimum engine performance at all rpms
• 2 into 1 exhaust system.
• large diameter header pipes for maximum flow; rear header pipe "snakes" forward to provide the correct tuned length.
• slightly upswept, dual stage muffler produces a low, throaty V-Twin growl & features an aluminum end cap
• heat shields protect rider & passenger from hot components
• 3-way honeycomb catalyzer reduces harmful exhaust emissions
• Air Injection System injects fresh air into exhaust ports to fully burn any unburnt fuel, further reducing exhaust emissions.
/// CHASSIS
• Tube type, double cradle steel frame with exposed rear subframe.
• provides a natural riding position & roomy ergonomics
• frame utilizes a rigid engine mounting system optimizing the overall chassis rigidity balance for superior handling
• engine mounting position provides a low center of gravity for light, easy handling
• Tube-type, steel, swingarm compliments the frame & features a dual shock rear suspension system.
• 1575 mm (62") wheelbase provides light, agile handling, for a fun riding experience.
• 41mm KYB front fork offers 120 mm (4.7") of wheel travel.
• good ride comfort & compliance
• traditional "scrambler style" fork boots ("gaiters") help prevent fork tube "nicks" & protect fork seals
• Adjustable, premium, remote reservoir, dual gas charged shock rear suspension. Rear wheel travel is 70 mm (2.8").
• 5 - positions of spring preload adjustability to suit load and / or rider preferences
• remote reservoir design keeps the shock cooler for more consistent damping performance
• Single, 298mm front disc brake features a floating, wave-style disc squeezed by a twin piston caliper.
• strong, confidence-inspiring stopping power
• wave-style disc offers more surface area than a conventional round disc for excellent heat dissipation
• 298 mm rear wave-style disc brake is squeezed by single piston caliper.
• caliper mounted to the underside of swingarm, reducing the centre of gravity for light handling
• location also hides the caliper for a clean, custom look
• Classic, spoked, scrambler style 19" front & 17" aluminum wheels.
• lightweight design reduces unsprung weight for superior suspension performance
• front rim size is 2.50 x 19" // rear rim size is 3.50 x 17"
• dual sport, wide block tread design (90% on road / 10% light off road)
• Fun styled, retro scrambler body work
• Steel fenders front & rear steel for easy re-painting or customization.
• 13 litre, slim design, teardrop shaped, flangeless fuel tank.
• 2.8 litre reserve capacity (low fuel light illuminates)
• flangeless design provides a clean custom look
• Slim, low profile one piece rider & passenger seat.
• good comfort & support
• seat height is 830 mm (32.7")
• slim design makes it easier to touch ground
• traditional passenger grab strap
• Lightweight aluminum rider foot pegs are positioned almost directly below the seat.
• traditional, natural upright riding position
• Wide, scrambler style 7/8" conventional handlebar with reinforcing crossbar for added strength.
• provides an upright riding position & excellent rider comfort
• wide design for easy handling & that special scrambler image
• bar can be changed to a different "bend" for easy customization or personal preferences
• Triple clamp mounted LCD digital meter / instrument.
• functions include; speedometer, odometer, dual trip meters, fuel reserve trip meter (counts kilometers since low fuel light activated), clock & range of warning lights
• instrument functions can be "tabbed" through & reset using the LHS handlebar switch gear, allowing the operator to change instrument functions without taking hands off the bars.
• 60/55 watt high intensity halogen headlight with chromed bezel.
• Round "vintage design" LED tail light.
• The SCR950 is designed to be compact & slim, featuring clean, simple styling with the ability to easily personalize / customize the bike with a wide range of Genuine Yamaha accessories.
/// DETAILS
• classic vintage styled graphics
• high mounted front & rear turn signals
• upper & lower belt drive cover helps prevent debris from entering the belt and pulley areas
• fork mounted steering lock
• self-cancelling turn signals
• traditional dipstick to check oil level
• Yamaha diagnostic service tool coupler
• Low-maintenance, sealed battery (battery should be charged during winter storage)
2017 Yamaha SCR950 - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $8,699 USD
Canada MSRP Price: $10,199 CDN
Engine Type 58-cubic-inch (942cc) air-cooled SOHC 4-stroke
V-twin; 4 valves
Bore x Stroke 85.0mm x 83.0mm
Compression Ratio 9.0:1
Fuel Delivery Fuel injection
Ignition TCI: Transistor Controlled Ignition
Transmission 5-speed; multiplate wet clutch
Final Drive Belt
Suspension / Front Telescopic fork, 4.7-in travel
Suspension / Rear Dual piggyback shocks, 2.8-in travel
Brakes / Front Wave-type disc, 298mm
Brakes / Rear Wave-type disc, 298mm
Tires / Front 100/90-19
Tires / Rear 140/80R17
L x W x H 88.6 in x 35.2 in x 45.9 in
Seat Height 32.7 in
Wheelbase 62.0 in
Rake (Caster Angle) 28.4°
Trail 5.1 in
Ground Clearance 5.5 in
Fuel Capacity 3.2 gal
Fuel Economy** 51 mpg
Wet Weight 547 lb
2017 Motorcycle Model Guides
Re: This Week: 2017 Yamaha SCR950 - VOTE NOW
Unread post by totalmotorcycle » Fri Jun 17, 2016 12:02 pm
Editor's note: It's a rare day where I'll put back-to-back manufacturers up on the Cool Wall. But this week's bike is completely new from Yamaha as well. The 2017 Yamaha SCR950 is a different direction for Yamaha... what do you think of it?
montanalifter
Real Name: Bill
My Motorcycle: Yamaha FJR 1300, Yamaha Stratoliner
Unread post by montanalifter » Fri Jun 17, 2016 12:24 pm
I like the retro look. Cool.
Years Riding: 41
Unread post by High_Side » Sat Jun 18, 2016 8:52 am
Not really all-new, just more of a reconfigured bolt. I love the idea but they should have made a specific dirt-tracker frame rather than trying to make a cruiser look like a dirt-tracker in my opinion.
Jarlaxle
Real Name: John
My Motorcycle: 2012 Suzuki Burgman
Unread post by Jarlaxle » Sat Jun 18, 2016 11:45 am
Voted "uncool"...it would get "awesome" if not for the antiquated engine.
Gummiente
Years Riding: 35
My Motorcycle: '15 HD Road Glide
Unread post by Gummiente » Sat Jun 18, 2016 1:55 pm
If a Harley Sportster and a Triumph Bonneville had a baby, this is what it would look like.
I like the styling, but the v-twin motor looks out of place. As we don't have a "meh" option, I am abstaining from this vote.
:canada: Mike :gummiente:
'15 Road Glide
"If loud pipes really did save lives, imagine what you
could accomplish if you learned how to ride that thing"
Grey Thumper
Real Name: Dino
Unread post by Grey Thumper » Sun Jun 19, 2016 1:28 am
I like the Bolt, and I like this one even more. Awesome for me. But it seems not enough people complained about the Bolt's gauges that Yamaha just carried over the same rinky dink, cheap, 80s-looking LED display. Is a rotating needle so much more expensive? I appreciate most of the SCR's "retro styling" but the gauges are from the wrong decade. ;P
ceemes
Real Name: a big secret
Unread post by ceemes » Sun Jun 19, 2016 10:41 am
Who remembers the term Yama Davidson? Well it's back. uncool.
Gummiente
Years Riding: 35
Unread post by Gummiente » Sun Jun 19, 2016 12:10 pm
ceemes wrote:Who remembers the term Yama Davidson? Well it's back. uncool.
I always thought it was "Yamaharley" or "Yamahog".
'15 Road Glide
Unread post by dr_bar » Mon Jun 20, 2016 6:20 am
Not at all impressed...
Unread post by totalmotorcycle » Fri Jun 24, 2016 8:51 am
Gummiente wrote:If a Harley Sportster and a Triumph Bonneville had a baby, this is what it would look like.
LOL! :laughing:
Triley Sportville
Unread post by totalmotorcycle » Fri Jun 24, 2016 8:54 am
Grey Thumper wrote:I like the Bolt, and I like this one even more. Awesome for me. But it seems not enough people complained about the Bolt's gauges that Yamaha just carried over the same rinky dink, cheap, 80s-looking LED display. Is a rotating needle so much more expensive? I appreciate most of the SCR's "retro styling" but the gauges are from the wrong decade. ;P
Ya, I never liked the Bolt's digital gauge either, seems they missed the mark by not putting in a dual pod needle tach and speedo setup (which is by FAR my fav)...
Unread post by totalmotorcycle » Fri Jun 24, 2016 9:00 am
I voted: Awesome
Ok, call me crazy, but I actually think the SCR950 competes against the new Triumph Bonneville T120 ( http://www.totalmotorcycle.com/motorcyc ... e-T120.htm ) similar power, styling, engine size and weight, but the advantage of the SCR950 being a V-Twin and cheaper to buy/own. In fact, while I love the new T120, I think the SCR950 actually looks even better... wow.
So that said, I know the Bolt isn't the most modern design, but vs the Bonnie, it's a decade ahead!
That to me, makes it awesome in my eyes.
Unread post by totalmotorcycle » Fri Jun 24, 2016 9:13 am
Featured: June 17th - June 24th, 2016
Motorcycle Cool Wall discussion: viewtopic.php?f=61&t=53212
Total Motorcycle model page: http://www.totalmotorcycle.com/motorcyc ... SCR950.htm
Awesome (3 points) 47% [ 7 ]
Cool (2 points) 13% [ 2 ]
Uncool (1 point) 40% [ 6 ]
Fail (0 point) 0% [ 0 ]
Total votes: 15
= a Coolwall Factor of 68.9%
Notes: Wow, usually you don't have a split vote between uncool and awesome. Just like the Brexit vote last night, this vote and the opinions are quite split! Riders would like to see an updated engine and retro gauges. Yes, that sounds odd when you want something very new and very old as well and I bet that confuses the heck out of Yamaha! lol. On a side note, I think the SCR950 competes vs the Triumph Bonneville T120 on the showroom floor, it will be interesting to see how it sells.
Users browsing this forum: CycleBlueBook, JackoftheGreen, montanalifter, ZRex and 140 guests
cron
