2016 Aprilia Dorsoduro 750 ABS - Coolness Factor = 83.3%
Your Coolness Factor of the 2016 Aprilia Dorsoduro 750 ABS is:
View results
Unread post by totalmotorcycle » Fri Jul 15, 2016 12:06 pm
2016 Aprilia Dorsoduro 750 ABS Review on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... 50-ABS.htm
To stand out. Always...
The Aprilia Dorsoduro 750 is equipped with the best braking technology currently available. The front brakes feature 4-piston radial calipers, state-of-the-art for the motard market. The light weight, 320 mm wave discs ensure shorter than ever stopping distances. The bikes aggressive stopping power is emphasized by the mean look of the braking system, in keeping with the Dorsoduros overall styling.
The rear brakes incorporate another wave disc, 240 mm in diameter this time, plus a single piston caliper. Both the front and rear brakes are fitted with aeronautical type metal braided brake lines to eliminate the sponginess associated with conventional rubber hoses and to deliver maximum braking precision.
A sophisticated two channel Continental ABS system provides maximum active safety on the Dorsoduro 750. The ABS controller is specially calibrated to make full use of the Dorsoduros impressive braking power and tire grip on dry surfaces. Riders can therefore still enjoy this amazing fun bike to the full.
Developed in close collaboration with Aprilia Racing, Dorsoduro 750 ABS was designed by taking the best features of sports bikes and supermotards, producing a perfect combination of performance, technology and fun. Power, lightness and agility, but also directionality, responsiveness and steering precision are therefore its main characteristics. Aprilia Dorsoduro ABS has components, technical features and finish of the highest quality which contribute to the uniqueness of the project. For the entire Dorsoduro 750 range, as the Shiver 750 range and the automatic Mana 850 from Aprilia, 35 kW powered-down versions are also available, in compliance with the criteria of the new A2 license.
A UNIQUE MOTORCYCLE WITH AN UNMISTAKABLE CHARACTER, DEVELOPED FROM APRILIA'S RACING EXPERIENCE WITH A SINGLE-MINDED GOAL: TO OFFER TOTAL RIDER ENJOYMENT. 92 HORSEPOWER AND EXCLUSIVE TRI MAP RIDE BY WIRE TECHNOLOGY IN A LIGHTWEIGHT, HIGH PERFORMANCE BIKE CREATED TO COMPLEMENT THE SKILLS OF EVEN THE MOST DARING RIDERS AND ALSO AVAILABLE WITH ABS.
APRILIA DORSODURO 750
Developed in collaboration with the Aprilia Racing Division - which has thirty-seven world championships under its belt - Aprilia Dorsoduro 750 has been created by fusing the best characteristics of a sports bike with the best that a racing super-motard has to offer. The result is the concentrated essence of performance and technology, a genuinely special, extreme and elite bike that can make any rider feel like a pro.
Light, agile and powerful, Dorsoduro 750 is powered by a latest generation engine and boasts the most advanced technology in its class. Through the use of state of art electronic engine management, Aprilia's compact 90° V-twin delivers blistering performance unmatched by any of its rivals, with an incredible specific power output of 122.6 hp/litre and a maximum torque of 82 Nm at just 4500 rpm.
True to Aprilia tradition, the chassis architecture is unparalleled in its class. After the acclaimed debut of the mixed trellis/aluminium frame on the ultra-specialised SXV, the application of the layout in the Dorsoduro establishes it a hallmark feature of Aprilia motards, offering levels of directional agility, reactivity and steering precision far beyond the reach of any rival.
The essentially designed Aprilia Dorsoduro boasts only the best in terms of componentry, technical specifications and finish. Four-piston radial callipers, wave discs, a hydraulic wet clutch, adjustable suspension front and rear, "Tri-Map" ride by wire and the Matrix instrument panel with on board computer all contribute to making the Dorsoduro a truly unique product.
Aprilia Dorsoduro 750 ABS http://www.Totalmotorcycle.com Key Features
" 90° V2 engine, four valves, double overhead camshaft, liquid cooling;
" second generation "Tri-Map" Ride by Wire technology;
" electronic fuel injection with state of the art injectors;
" Mixed gear/chain timing system;
" ultralight modular trellis/aluminium frame with superlative torsional stiffness;
" aluminium swingarm with lateral shock absorber;
" fully adjustable 43mm upside down fork;
" radial front brake callipers working in conjunction with 320 mm Wave discs;
" 25 kW version for newly qualified riders;
" latest generation 2-channel Continental ABS;
ENGINE
Numerous improvements have been made to the Aprilia 750 cc, 90 V twin engine, which now features mapping specially developed to bring out the Dorsoduros aggressive character.
Improvements have been made to various areas of the749.9 cc engine with its bore and stroke of 92 x 56.4 mm.As a result the electronic and mechanical content of thisV twin engine sets new standards not only for engines of this size but for many far larger units too.The electronic engine management on the Dorsoduro 750s engine leads the field in technology and performance. The Dorsoduro features a second generation electronic throttle with Tri-Map selectable triple mapping.
2016 Aprilia Dorsoduro 750 ABS - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $10299 USD
Canada MSRP Price: $10895 CDN
ENGINE
Engine type Aprilia V90 four-stroke longitudinal 90° V-twin engine, withliquid cooling, double overhead camshafts driven by mixed gear/chain timing system, four valves per cylinder and Ride by Wire throttle control.
Capacity 749.9 cc
Max power (at crankshaft) 92 HP (67,3 kW) at 8,750 rpm
Max torque (at crankshaft) 60.4 lb-ft (82 Nm) at 4,500 rpm
Fuel system Integrated engine management system. Latest generation 3 maps (Sport, Touring, Rain) Ride-by-Wire throttle management.
Exhaust 2 into 1 exhaust system in 100% stainless steel with three-way catalytic converter and lambda probe
TRANSMISSION
Gearbox 6 speeds
Lubrication Wet sump
Clutch Multiplate wet clutch, hydraulically operated
CHASSIS / SUSPENSION / BRAKES
Chassis Modular tubular steel frame fastened to aluminium side plates by high strength bolts. Removable rear subframe
Front suspension Ø43 mm upside-down fork, with adjustable hydraulic rebound damping and spring preload. Wheel travel 160 mm.
Rear suspension Aluminium alloy swingarm. Hydraulic shock absorber, with adjustable rebound and preload. Wheel travel 155 mm.
Front brake Dual Ø320 mm stainless steel floating wave discs. Four piston radial callipers. Metal braided brake lines.
Rear brake Ø240 mm stainless steel wave disc. Single piston calliper. Metal braided brake lines.
ABS Two-channel Continental ABS system
Wheels Aluminium alloy
Front tire Radial tubeless; 120/70 ZR 17
Rear tire Radial tubeless; 180/55 ZR 17
DIMENSIONS
Max. Length 8732 in. (2,216 mm)
Max. Width 35.6 in. (905 mm)handlebar)
Max. Height 46.6 in. (1,185 mm) at instrument panel
Seat height 34.2 in. (870 mm)
Dry weight 409 lbs (186 kg)
Fuel tank capacity 3.17 gal. (12 lt)
2017 Motorcycle Model Guides
Re: This Week: 2016 Aprilia Dorsoduro 750 ABS - VOTE NOW
Unread post by totalmotorcycle » Fri Jul 15, 2016 12:16 pm
Something a little different in the mix this week.
Enjoy!
faded sun
Years Riding: 42
Unread post by faded sun » Tue Jul 19, 2016 9:56 pm
We are speechless before this model it seems. I was too but have concluded it is at least cool. Mostly looking to ride two-up I am not interested in owning one, but I would certainly take this out for a spin. Or to the track.
Well done Mike for stumping your audience once again!
Jock
Grey Thumper
Real Name: Dino
Unread post by Grey Thumper » Wed Jul 20, 2016 1:31 am
I really like these supermoto-styled naked bikes. You get good visibility because of the high motocross seat design, minimal bodywork, light weight, great power-to-weight ratios, and they tend to be relatively slim. Good suspension travel tends to smooth out bad roads too. They make great urban/commuting bikes. Tiny tanks and uncomfortable seats are, unfortunately, also the norm though.
As for the Dorso specifically, based on that rear end alone, it should get an awesome vote.
Unread post by totalmotorcycle » Fri Jul 22, 2016 1:35 pm
faded sun wrote:We are speechless before this model it seems. I was too but have concluded it is at least cool. Mostly looking to ride two-up I am not interested in owning one, but I would certainly take this out for a spin. Or to the track.
LOL, thanks for the compliment!
I do love putting up models that make a rider think outside the box. It's easy to slap an "awesome" on a popular model, but something that is different, unique and not seen very much, it can be a head-scratcher. :)
Unread post by totalmotorcycle » Fri Jul 22, 2016 1:41 pm
I love it. Voted: Awesome.
It's like a Ducati or a KTM but at an affordable price AND you get a prestigious brand name as well! Plus, look at what Piaggio is offering up the motorcycling community, USA and Canadian prices that are almost identical! For either group, the MSRP is a bloody-bargain for what you get, hands down.
The bike itself, wow. V2 engine, 92hp, lightweight 409lbs, awesome looks, dual-fighter jet tail exhaust... wow. Awesome+
Yes, I do agree 101% with Grey Thumper there, the 12l size, that's a little small. Might get 100-120 miles out it before hitting reserve. Which isn't bad and if you use the Dorsoduro 750 for mostly city/day trips, it's on the line of "fine". But a bigger tank would be a welcomed addition.
Sweet bike.
Unread post by totalmotorcycle » Fri Jul 22, 2016 1:54 pm
Featured: July 15th - July 22nd, 2016
Most popular vote category: Tie Awesome/Cool
Motorcycle Cool Wall discussion: viewtopic.php?f=61&t=53327
Total Motorcycle model page: http://www.totalmotorcycle.com/motorcyc ... 50-ABS.htm
Awesome (3 points) 43% [ 9 ]
Cool (2 points) 43% [ 9 ]
Uncool (1 point) 10% [ 2 ]
Fail (0 point) 5% [ 1 ]
Total votes: 21
= a Coolwall Factor of 83.3%
Notes: Simply. The best bang for your buck in it's category. Not only that, but the 2016 Aprilia Dorsoduro 750 ABS becomes our #1 most cool bike on the Cool Wall (as of writing) bumping off the 2016 Norton Dominator SS (Voted - 82.6% Cool) that's been in the #1 spot since Feb 19th, 2016!!
Users browsing this forum: JackoftheGreen, jstark47, Majestic-12 [Bot], markdcoco, montanalifter, Rubiadiabla and 187 guests
cron
