#350: 2018 Kawasaki Z900RS SE - Coolness Factor = 90.9%
Your Coolness Factor of the 2018 Kawasaki Z900RS SE
29
83%
6
17%
0
No votes
0
No votes
Total votes: 35
Years Riding: 32
2018 Kawasaki Z900RS SE on the Total Motorcycle Cool Wall
For MORE information and Photos click here: https://www.totalmotorcycle.com/motorcy ... -se-review
TRUE SPIRIT.
2018 Kawasaki Z900RS SE Review on Total Motorcycle:
Introducing Kawasaki’s long-awaited retro sport model. Conceived in homage to the legendary Z1, the newest Z is a synthesis of the traditional and the modern. An engine with a traditional In-Line Four configuration is backed by Kawasaki’s latest rider support technology. For riders searching for a bike with character and a rich history, the Z900RS offers both in abundance, while providing an opportunity to slow down, look around and enjoy the simple things that life can bring.
There’s no place for fake in the lifestyle you choose. Kawasaki alone has the heritage to deliver yesterday’s values to today’s riders in a truly authentic Modern Classic bike. The visceral spirit of a 1970s legend – Kawasaki’s original king of cool Z1 – finds expression in the Z900RS, to satisfy the very essence of the rider you are now.
2018 Kawasaki Z900RS SE Totalmotorcycle.com Key Features
2018 Kawasaki Z900RS SE Totalmotorcycle.com Features and Benefits
EXCLUSIVE ON THIS VERSION
KTRC (Kawasaki TRaction Control)
Contributing to rider reassurance, the Z900RS is equipped with advanced Kawasaki rider support technology. KTRC features two modes that cover a wide range of riding conditions, offering either enhanced sport riding performance or the peace of mind to negotiate slippery surfaces with confidence.
Dual-Dial Instrumentation with Multi-Function LCD
Analogue-style speedometer and tachometer dials are complemented by a multifunctional LCD screen, balancing retro-style looks with modern functionality.
Radial-Mount Front Brakes
ø300 mm front discs gripped by radial-mount calipers provide sure, strong stopping power. Radial-pump front brake master cylinder contributes to brake touch and control.
ERGO-FIT
ERGO-FIT is an interface system that allows a wide range of riders to feel at one with their machine.
ABS
ABS (Anti-lock Brake System) ensures stable braking performance by preventing wheel lock during braking.
Horizontal Back-link Rear Suspension
Horizontal Back-link Rear Suspension arranges its shock unit horizontally, greatly contributing to efficient use of space and mass centralisation.
Assist & Slipper Clutch
Based on racing technology, the Assist & Slipper Clutch acts as both a back-torque limiter and a self-servo mechanism that enables a lighter clutch lever pull.
Dual Throttle Valves
Dual Throttle Valves offer increased power and greater ease of use care of a second set of ECU-controlled throttle valves.
Economical Riding Indicator
The Economical Riding Indicator is a mark appearing on the instrument panel to indicate favourable fuel consumption, encouraging fuel efficient riding.
KTRC (2-mode)
Two modes KTRC cover a wide range of riding conditions, offering either enhanced sport riding performance or the peace of mind to negotiate slippery surfaces with confidence.
2018 Kawasaki Z900RS SE – Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $TBA USD
Canada MSRP Price: $13,199 CDN
Engine
Displacement 948cc
Type 4-stroke, In-Line Four
Bore and stroke 73.4 x 56.0 mm
Cooling Liquid
Compression ratio 10.8:1
Valve system DOHC, 16 valves (4 valves per cylinder)
Fuel system 36 mm x 4 with sub-throttles
Ignition Digital
Lubrication Forced lubrication (wet sump)
Brakes
Front: type Dual semi-floating 300 mm petal discs
Front: calipers Dual radial-mount, monobloc, opposed 4-piston
Rear: type Single 250 mm disc
Rear: calipers Single-piston caliper
Dimensions
Overall length 2,100 mm
Overall width 865 mm
Overall height 1,150 mm
Wheelbase 1,470 mm
Ground clearance 130 mm
Seat height 800 mm
Curb mass** 214 kg
Fuel capacity 17 litres
Drivetrain
Transmission 6-speed, return
Final drive Chain
Primary reduction ratio 1.627 (83/51)
Gear ratio: 1st 2.917 (35/12)
Gear ratio: 2nd 2.059 (35/17)
Gear ratio: 3rd 1.650 (33/20)
Gear ratio: 4th 1.409 (31/22)
Gear ratio: 5th 1.222 (33/27)
Gear ratio: 6th 0.967 (29/30) [
Final reduction ratio 2.800 (42/15)
Clutch Wet multi-disc, manual
Frame
Type Trellis, high-tensile steel
Wheel travel: front 120 mm
Tire: front 120/70-ZR17M/C (58W)
Wheel travel: rear 140 mm
Tire: rear 180/55-ZR17M/C (73W)
Caster (rake) 25º
Trail 98 mm
Steering angle (left/right) 35° / 35°
Performance
Maximum Power‡ 82 kW {111 PS} / 8,500 rpm
Maximum Torque‡ 98 N·m {10.0 kgƒ·m} / 6,500 rpm
Suspension
Suspension, front 41 mm inverted fork with compression and rebound damping and spring preload adjustability
Suspension, rear Horizontal Back-link, gas-charged shock with rebound damping and spring preload adjustability
Details
Warranty 12 months warranty
2023 Motorcycle Model Guides
Years Riding: 32
Re: #350: 2018 Kawasaki Z900RS SE - VOTE NOW
Just released from Kawasaki for 2018... the Retro Z900RS!
To avoid confusion, the Z900RS is available in 3 different models (depending on where you are). No information yet out of Kawasaki if it is coming to the USA... The Z900RS SE is an interesting overlap model with the UK version. In the UK, the normal RS is offered in the same retro paint, but in Canada the RS is only black.
– 2018 Kawasaki Z900RS Cafe^ – New model (Canada, Europe)
– 2018 Kawasaki Z900RS SE^ – New model (Canada, Europe)
– 2018 Kawasaki Z900RS^ – New model (Canada)
Thanks to montanalifter for suggesting this week's Cool Wall bike.
montanalifter
Real Name: Bill
#3 Unread post by montanalifter »
Love the look reminds me of my kz650 when I was in high school. 109 horses with 450lbs should get you going well also. The dual analog gauges are nice as it would seem weird to have a digital speedo on a bike like this. I voted awesome.
ZRex
Real Name: Ben
#4 Unread post by ZRex »
Awesome, I would vote Awesome on all of the Z900s.
ceemes
Real Name: a big secret
#5 Unread post by ceemes »
I am sorry, but I just can't vote awesome for this bike.....I'd dearly love to, but I just can't. It is beautiful, it hearkens back to a time when motorcycling was "pure", just you, your machine and the road, its got the "right" engine, a naked inline four just screams Japanese muscle, minimal body work and just pure naked loveliness. And that traditional bench saddle...sigh.......but given all that and more, I just cannot in all honesty vote awesome, nor even cool for that matter........
.....coz this bike transcends awesome and we need a whole category Mike.......Sub Zero....Uber Kool......Heat Death Cool.......
NorthernPete
Years Riding: 11
#6 Unread post by NorthernPete »
Love it. And it's got 2 wheels.
2009 GS500F
montanalifter
Real Name: Bill
#7 Unread post by montanalifter »
(admin notes: I changed your video, hope you don't mind)
Years Riding: 32
I am with ceemes here. Is there something more than AWESOME to vote?
I voted: Awesome.
Wow, amazing. It is like I just time traveled to when the Z1 was offered for sale. Amazing retro job. I guess if you never seen the original nor have any connection to the Z1/Z900 then I could see this as an "old bike"... maybe that is what the 60-70's inspired bikes look to those older than me? I don't have a connection to say a 40s Indian or 50s Harley-Davidson, but I do with the 70s and 80s UJMs... Interesting thoughts.
Anyways, Kawasaki did an amazing job recreating the original bike to today's designs and style. It has everything I would want as a rider... but what does it sound like? It is revvy and loud sounding like those UJMs of old? Or like a more modern I4 that's quiet? Will I fit on it? I didn't fit on the Honda CB1100 retro to much disappointment.
Price is ok, power is more than fine, tank is a little small at 17l, But really, if you want one, BUY ONE, don't let the new Z900RS fall the same way the ZRX1100R and ZRX1200R did (slow sales). I really loved those ZRX's, rode one, almost bought it, but the looks didn't match it's character.
It will be interesting to see if the new 2018 Kawasaki Z900RS SE beats our #1 bike of the year so far, the 2018 Honda Gold Wing!
Years Riding: 32
Featured: November 10th, 2017 - November 17th, 2017
Motorcycle Cool Wall discussion: viewtopic.php?f=61&t=54541
Total Motorcycle model page: https://www.totalmotorcycle.com/motorcy ... -se-review
Awesome 16
Cool 6
Uncool 0
Fail 0
Total votes: 22
= a Coolwall Factor of 90.9%
Total Motorcycle's Take-a-Way: Amazing retro. It is not just that it looks retro, it is the skillful implementation of the design and technology to not spoil the heritage appearance. If you had ANY positive connection to 70s/80s UJMs and you love the looks of the new Z900RS, then you deserve to own this bike. There are some cons (small tank, could be a little better priced), maybe you are not a fan of the color scheme, but again, if you have a connection, these cons will disappear as the miles roll by. I was a little worried Kawasaki was not going to bring any of the new retro Z900s to North America as the ZRX1100R/1200R sales were slow, I hope the Z900RS sells like hot cakes.
For those interested, the new Z900RS finished #2 as our Cool Wall bike so far, missing the #1 bike, the new Honda Gold Wing, by 1 awesome vote.
Cool Wall Comment of the Week: This week's comment is actually a video:
- Markdecoco
