Short experienced rider wants bike any suggestions?
Posted: Sun Jun 14, 2009 11:20 am
by delyn
I am new here but not new rider. I am 4'10 and my first bike was a 883 hugger. Haven't ridden for several years and am looking for a "new" to me bike. I have been checking out the rebel and the suzuki 250's because of seat height is lower and I can't afford an HD right now. I am looking for a cruiser to commute to college in Orlando. My question is... after riding an 883 would you all recommend to 250 or should I look into a 650 or 700 and make adjustments for the seat height? Also how much does it cost to make adjustments these types of changes?
Thanks for any input.
Posted: Sun Jun 14, 2009 2:08 pm
by SCgurl
If I were you, I wouldn't count out the bikes in the 600-800 range. You might be able to take some foam off the seats, lower the bike, etc. What's your inseam? I have a 30" inseam and have lots of leg to spare on the S40.
Wish I could give you an idea of cost-I'm just now starting to consider mods for the new bike to get it to "my size". It's a Road King I can't flatfoot, but I'm securely on the balls of my feet. A completely different seat (narrower) would run about $300; the low profile shocks would be $250, but would also change the handling.
The seat on the S40 is already pretty narrow, and I didn't feel like it was that much taller than the GZ, just longer. IIRC, the V-Stars had a lower seat height than the S40.
Posted: Sun Jun 14, 2009 3:34 pm
by delyn
My inseam is around 26 inches.
Posted: Sun Jun 14, 2009 5:13 pm
by SCgurl
Aha! Found it!
For inseam guidance:
viewtopic.php?t=7851
It doesn't take into account how wide the seats are, but it's a good starting point. I believe these are unladen heights, but I could be wrong.
Posted: Sun Jun 14, 2009 10:49 pm
by blues2cruise
A friend of mine got the seat narrowed which helped a bit.
You could also inquire about low profile tires.
Posted: Mon Jun 15, 2009 8:37 am
by follow
27" inseam and just miss the 5'3" mark here...
I think if you went backwards as far as engine size, you may not be happy. But this is my humble opinion others may think differently. If you were a hugger rider, the others on the short list will be a piece of cake they are not so top heavy (one of my old bikes was a hugger).
I had to have seats modified on bikes and custom shocks.
you can PM me if you like.
Posted: Mon Jun 15, 2009 10:54 pm
by delyn
Thanks for the seat height listing and the helpful advice everyone.
I think I will probably go for the middle range cc's as I know I can handle that size and with the right seat adjustments and shorter shocks as I only weight in at 120lbs I should be good.
Going to look at a honda shadow 700cc tomorrow. Keep your fingers crossed.
Ride safe
Posted: Sat Jun 27, 2009 1:38 am
by arletian
I'm also 4'10 and about 100 lbs. I just bought my first motorcycle ever, a dream I had since I was 13 years old. I got a 1996 Honda Rebel for about $1600, and I can easily touch the ground. I love it!
You can also check out this list that has motorcycle seat heights.
Good luck!!!
Posted: Sat Jun 27, 2009 2:00 am
by blues2cruise
arletian wrote:I'm also 4'10 and about 100 lbs. I just bought my first motorcycle ever, a dream I had since I was 13 years old. I got a 1996 Honda Rebel for about $1600, and I can easily touch the ground. I love it!
Good luck!!!
:welcome2:
Re: Short experienced rider wants bike any suggestions?
Posted: Sat Jun 25, 2011 7:46 am
by hartley1
cost won't be high as per your required changes . !
