honda xl 600 sprocket heeelllllppppp!!!
djjusty
#1 Unread post by djjusty » Tue Mar 25, 2008 7:12 pm
hi there i have got my self an 1984 honda xl 600, i am having trouble trying to obtain rear sprocket for ot, the one on it at the moment is a 41 tooth, i am trying to find a 47 or a 50 tooth one, any help would be appreciated,
the counter bore is 130 mm,
the size and pitch of chain is 520
drum brake
pcd fixing is 150 mm
6 bolt holes, 8mm and counter sunk to 17mm
is there any other bike out there would share the same size sprocket????
i did try and line up a dzr 400 one but 2 mm out in bore diameter.
justin
UPDATE, THANKYOU FOR YOUR HELP, THE XR 600 SPROCKET WHICH I HAVE ORDERED AND FITS PERFECT, HAD TO ORDER NEW CHAIN AS WELL AS OLD ONE TO SMALL , BUT ALL SEEMS TO BE OK
Gadjet
Real Name: Owen Clark
My Motorcycle: currently looking for new
#2 Unread post by Gadjet » Wed Mar 26, 2008 8:16 am
Dennis Kirkcarries 41, 43, and 53 tooth rear sprockets for your bike.
the link will open in my account, so you'll have to log out and create your own account if you want to order from them. You'll want to replace your front sprocket and chain at the same time, and also make sure that you get the right size chain to fit with the larger sprocket.
1983 Suzuki GS650GL (sold)
2005 Kawasaki KLR 650 (sold)
IBA#20953
paul246
#3 Unread post by paul246 » Fri Mar 28, 2008 6:46 pm
Honda XR650L Dual-Sport
