I'm all for safety, but a motorcycle airbag? Apparently Yamaha, and Honda are experimenting with airbags. How effective do you think that can be in the average motorcycle accident? At best it may help in a low speed front on collision. What's your take on this?
I can't really see how this will work. It may stop a rider from flying forward but then they would retrack backwards. I like the inflatable jacket or suit. Upon being ejected from the bike, the suit will inflate and help soften the impact of landing. I think this is a much better method.
Friends help you move. Real friends help you move bodies.
Seems the biggest problem here is impacting objects around you. So how about an ejector seat that launches you high into the air and then releases a parachute that lets you drift slowly to the ground while you watch the rest of the accident unfold below you.
Assuming you dont wreck in a tunnel that is.
2002 Buell Blast 500 /¦\
You don't bounce off the bag. They have big holes in them to let the gas out as you hit them. Pushing the gas out takes energy... and any energy spent deflating a gas bag can't then be spent damaging your tender flesh.
Bouncing is bad... bouncing reclaims the energy... which means it will be transfered to you again, over and over again. If you ever have an airbag suit, hope it doesn't bounce....
