Is it suspost to be a aluminum crush whasher or a thick steal whasher?
Thanks
Oil drain plug sealing whasher for 2005 Honda Sadow Spirit
Not familiar with your particular bike, but I'd bet big money that it's the exact same aluminum washer that's on my 2 honda bikes (1986 250 and 1995 750, exact same washer and 17mm drain plug on each).
Steel bolt, aluminum pan, you probably don't want a steel washer, the soft alloy one will definately distort (to seal), rather than the pan distorting (bad).
You can re-use it a few times, and also please don't over-tighten the bolt.
- flynrider
- Years Riding: 30
After a few bad experiences like that in my early riding career, I just gave up on motorcycle shops altogether. I always seemed to have new problems after I got the bike back from the shop. About the only shop I see is the motorcycle tire shop. The do nothing but tires and have always done a good job. If anything else goes wrong, I drag out the shop manual.J.R. Bob Dobbs wrote:I agree!
That stinks they left out the drainplug washer....imagine what could happen when they remove axles/wheels or (gasp) open up the motor!! I found mangled bolt heads on the front axle clamp bolts on my Nighthawk, which had only been serviced by a honda dealer, until I bought it.
Bikin' John
'93 Honda CB750 Nighthawk
