i believe that it kills gas to the bike, not all the way, be a significant ammount so taht you can not longer accelerate at that level and let the RPMS falls, at least thats basically how it works on a car, so im guessing the same for a bikefireguzzi wrote:no it will not prevent you from red lining.
It will stop you from going too far past redline so your engine doesnt go kablewie.
I believe it affects your ignition, making your engine miss and skip.
It's just away to protect the engine.
+1, dont try to remove it and dont have anyone professinally remove itfireguzzi wrote:
IT WILL NOT AFFECT THE PERFORMANCE OF YOUR BIKE!!!! DO NOT ATTEMPT TO OVERRIDE IT!!!!!!
Sev wrote:What's a bike?
JWFJWF505 wrote:its like a goat, but with two wheels.
XM23 wrote:The rev limiter only prevents you from over reving the bike using the throttle.
It won't stop you from doing so by downshifting to 1st gear at 130 MPH and dumping the clutch.
TMW
Privacy Policy - Forum
Privacy Policy - Terms
and Conditions
Follow us on X / Twitter - Facebook - YouTube - Pinterest - Instagram - News RSS Feed |
