gave clutchless shiftng another shot. - Total Motorcycle Community Forums
Skip to content
Advanced search
  • Quick links
    • Unanswered topics
    • Active topics
    • Search
  • FAQ
  • Login
  • Register
  • Search
  • Unanswered topics
  • Active topics
  • Print view
Advanced search
  • 1
  • 2
  • 3
  • Next
VermilionX
  • Quote
#1 Post by VermilionX » Wed Jun 14, 2006 3:54 pm
my mechanic showed me a good method.
he told me to just apply pressure on the shifter, then when i let go of the throttle, it should fall into the next gear. i tried it for both up and down shifting.
it works!
well at least most of the time. :laughing:
i need to practice it more.
Ninja Geoff
Real Name: Geoff
  • Quote
#2 Post by Ninja Geoff » Wed Jun 14, 2006 3:57 pm
why not... just tweak the clutch?
half an inch is more than enough to smooth the shifting and make it still quick.
VermilionX
  • Quote
#3 Post by VermilionX » Wed Jun 14, 2006 3:59 pm
oh, i wasn't practicing it to be quick.
i was just practicing it for the sake of learning how to shift w/o the clutch.
ninja79
  • Quote
#4 Post by ninja79 » Wed Jun 14, 2006 4:19 pm
VermilionX wrote:oh, i wasn't practicing it to be quick.
uhhh.... riiight. And the point of that is....?
1will
  • Quote
#5 Post by 1will » Wed Jun 14, 2006 4:23 pm
ninja79 wrote:uhhh.... riiight. And the point of that is....?
tru...
anyway pro racers don't technically do clutchless shifting, right? isn't their shifter rigged to engage the clutch for them?
VermilionX
  • Quote
#6 Post by VermilionX » Wed Jun 14, 2006 4:25 pm
what if my clutch lever broke? knowledge of clutchless shifting will help, yes?
Shorts
  • Quote
#7 Post by Shorts » Wed Jun 14, 2006 4:30 pm
The point of it is to learn how to shift without the clutch. I case of emergency and you lose the clutch cable, you'll still need to limp home or somewhere safe to make repairs if you cannot do it on the side of the road.
Or in my case, you don't have a left hand to clutch with.
But, with clutchless shifting, timing is everything both for up and downshifts. Sometimes downshifting is harder to match the rpms. A nice blip of the throttle just before the clutchless downshift will match rpms enough the gear engages smoother.
Racers do use this clutchless upshifts with a pushbutton system. In racing it's done to reduce the human error (read: slower, less accurate shifts).
Ninja Geoff
Real Name: Geoff
  • Quote
#8 Post by Ninja Geoff » Wed Jun 14, 2006 4:31 pm
You'll have more problems than a broken clutch lever if you break your clutch lever.
The Grinch
  • Quote
#9 Post by The Grinch » Wed Jun 14, 2006 4:43 pm
VermilionX wrote:what if my clutch lever broke? knowledge of clutchless shifting will help, yes?
Maybe you should practice wheelies in case your front wheel falls off.
VermilionX
  • Quote
#10 Post by VermilionX » Wed Jun 14, 2006 5:09 pm
:laughing:
maybe i will.
  • Print view
  • 1
  • 2
  • 3
  • Next
Jump to
  • ↳   Total Motorcycle Talk
  • News, Events and Stories
  • Reviews
  • Rider Cafe'
  • Off Topic!
  • Total Motorcycle General
  • Board index
  • All times are UTC-11:00
  • Delete cookies
  • Contact us
Privacy | Terms
