Bike cover allows wetness in?
buddhacide
#1 Unread post by buddhacide »
We had out first rainfall for a while last night since i bought my bike. When I went to use my bike today I noticed that the bike was quite wet underneith its cover. Is this normal? I know these covers are designed to let moisture out, but not in.
Current: 2008 Vulcan 900 custom
Previous: 1999 V-star 650 custom
Z (fka Sweet Tooth)
#2 Unread post by Z (fka Sweet Tooth) »
It could be condensation or humidity that crept in..
jonnythan
#3 Unread post by jonnythan »
Ever sleep in a tent overnight? You get lots of condensation on the inside surface of the rainfly. Same thing happens with bike and car covers.
I imagine the process with bikes is the same as with cars.. keep the cover on when it's raining, but don't forget to take it off afterwards.
dieziege
#4 Unread post by dieziege »
If you think the cover is seeping some scotchguard sprayed on it will help the water flow away instead of through, but it won't help at all with condensation.
sharpmagna
#5 Unread post by sharpmagna »
Yup my bike gets wet under the cover too. If it is a good cover it should have vent holes to let the water evaporate. This is why you don't use a regular tarp. The tarp will just hold the moisture.
I'm using a Dowco Guardian cover btw.
1987 Honda <B>SUPER</B> Magna
ofblong
Real Name: Ben
#6 Unread post by ofblong »
it stopped most of the rain did it not :D. Like everyone else said probably just condensation
buddhacide
#7 Unread post by buddhacide »
Thats good then. It is ventilated to get rid of moisture, so I should be good.
