at the crank? and hp question. - Total Motorcycle Community Forums
Skip to content
Advanced search
  • Quick links
    • Unanswered topics
    • Active topics
    • Search
  • FAQ
  • Login
  • Register
  • Search
  • Unanswered topics
  • Active topics
  • Print view
Advanced search
  • 1
  • 2
  • 3
  • Next
VermilionX
  • Quote
#1 Post by VermilionX » Sun Jul 09, 2006 12:25 pm
i reading a review of the gixxer750 K6.
At the crank the claimed output is a whopping 150hp at 12,000 RPM, with 55ft-lbs of torque coming on strong at 10,500RPM. Compare those figures to the Gixxer 600’s maximum 50ft-lbs of torque shoving in at 7000RPM, and peak claimed 124 crank horses at 13,500 RPM and there’s no mystery as to who has the better midrange.
what does at the crank mean?
and
what's the difference between hp and bhp?
  • Quote
#2 Post by Sev » Sun Jul 09, 2006 12:27 pm
At the crank is measured at the engine. Basically with nothing hooked up too it.
bhp is brake hp, or the amount of HP that actually gets transfered to the wheels.
VermilionX
  • Quote
#3 Post by VermilionX » Sun Jul 09, 2006 12:31 pm
Sevulturus wrote:At the crank is measured at the engine. Basically with nothing hooked up too it.
ah i see... so that means the bike actually has less than 150hp right?
i heard a joke from my mechanic that a guy was asking how he can add more hp to his bike and he told the guy to remove the chain and the engine will make more hp. :laughing:
  • Quote
#4 Post by Sev » Sun Jul 09, 2006 12:47 pm
Your engine makes 150 hp, but it looses power because things like the sprockets, chain and wheel all need to be moved as well. So some of the power is wasted in moving the bits that make you move.
So when you measure the power that is put the pavement, you have all that extra weight between the engine and the rubber. Which come to think of it is probably why there are lighter chains and lighter wheels about.
That's also a part of the reason race bikes use chains rather then shaft drives. The heavier shaft drive (plus 2 direction changes for the supplied power) reduce the power that can be put to the pavement).
VermilionX
  • Quote
#5 Post by VermilionX » Sun Jul 09, 2006 12:55 pm
ah i see... thanks again for making that clear.
i also heard that chains are more sturdy and better for aggressive riding compared to a belt.
sharpmagna
  • Quote
#6 Post by sharpmagna » Sun Jul 09, 2006 1:01 pm
Yeah the chain will transfer the power more instantaneously compared to the belt because the belt will slightly deflect. That's why you'll see only chains on the race bikes.
1987 Honda <B>SUPER</B> Magna
VermilionX
  • Quote
#7 Post by VermilionX » Sun Jul 09, 2006 1:11 pm
so if the bike has 150hp... i wonder how much bhp it has. :?
and yeah, i know i could go to a dyno test but i'd rather not until i do some serious mods for before and after results.
jmillheiser
  • Quote
#8 Post by jmillheiser » Sun Jul 09, 2006 1:29 pm
bhp is the amount of hp at the crank. its called brake horsepower because the type of dyno that measures crank hp uses a brake to generate resistance against the engine to measure the hp.
whp or rwhp is wheel horsepower, this is the power measured at the drive wheel(s), this is done on the familiar chassis dyno that has the drum that is turned by the drive wheel.
shp or shaft hp is hp measured at the driveshaft, this hp measurement is used for aircraft engines but not car or motorcycle engines.
spinner
  • Quote
#9 Post by spinner » Sun Jul 09, 2006 2:05 pm
That whole article seemed like they wanted to bash the 600 more than praise the 750... Most reviews I read claim both bikes are essentially the same except for the engine output.
.:2006 GSX-R 600:.
[img]http://i85.photobucket.com/albums/k48/cspinner/65f4a1ec5a001a02396ac2d1baa8e31a.jpg[/img]
kabob983
Real Name: Chris
  • Quote
#10 Post by kabob983 » Sun Jul 09, 2006 2:15 pm
My buddy's got a 2000 R1 and it's 150 bhp, but rear wheel hp is more along the lines of 120 or so I believe.
2004 Suzuki SV650S (Sold)
Being bikeless SUCKS!!!
  • Print view
  • 1
  • 2
  • 3
  • Next
Jump to
  • ↳   Total Motorcycle Talk
  • News, Events and Stories
  • Reviews
  • Rider Cafe'
  • Off Topic!
  • Total Motorcycle General
  • Board index
  • All times are UTC-11:00
  • Delete cookies
  • Contact us
Privacy | Terms
