chain maintenance?
VermilionX
Super Legendary 5000
#31 Unread post by VermilionX »
Dichotomous wrote:thank you, camera phones and bars and buddies are wonderfull things, notice how on short posts I direct my insane gaze directly at my signeture too? an unplanned awsomeness of leering porportions
nice.. good luck on your new movie. i'll probably watch it. :laughing:
take care of your GF too.
Dichotomous
#32 Unread post by Dichotomous »
why thank you clarice, it was nice talking with you.
(I think she takes care of me more than the other way around, maternal instincts and all)
scan
#33 Unread post by scan »
VermilionX wrote:
scanevalexec wrote: Every 3 or 4 lubing times I'll run the chain cleaner across the chain (a little tool that wraps around the chain and lets you spray lube in while the chain is moving).
what's this "chain cleaner"?
It is a plastic square. Three of the sides stay in place on the forth one opens. Inside the square are plastic, rigid brushes. On the outside of the box is a little hole to squirt lube in through a tube. It is a small box, just big enough for a chain to fit through. It has a tie down so you can open the box, slip it over the chain, tie it down, and if you have it on a stand, a couple spins around the chain is clean. You do have to clean the box after though, but it does a great job on my chain every couple thousand miles.
* 2003 Kawasaki ZRX1200R *
DieMonkeys
Real Name: Mick
My Motorcycle: 2015/Kawasaki/Versys 650 LT
#34 Unread post by DieMonkeys »
Chain cleaner review:
http://www.totalmotorcycle.com/r3/kettenmax-chain-cleaner/
VermilionX
#35 Unread post by VermilionX »
im not quite sure i get how it works but i'll just ask this...
can i use it w/o a rear stand?
DieMonkeys
Real Name: Mick
#36 Unread post by DieMonkeys »
Check out the review ^^^ I don't think you can, you have to be able to move the rear wheel so that the chain moves, and I don't suggest using the throttle to turn the rear wheel.
VermilionX
#37 Unread post by VermilionX »
ok thanks...
looks like i need to buy a set of stands 1st before anything else right now.
scan
#38 Unread post by scan »
VermilionX wrote:im not quite sure i get how it works but i'll just ask this...
You could, but I think it is better with a rear stand. Otherwise you have to spray and roll and spray more and roll until the chain looks clean. With your bike, you need to invest in a rear stand (and maybe front).
Picture the chain on your bike. Now imagine reaching in and wrapping your fist around the chain. Now imagine inside the palm of your hand you have a bristles. Now, image you feed a hose between your fingers and feed lube in from a spray can. That is how the tool works. It wraps around the chain with a brush on the inside. You spray lube in and it breaks down the gunk and cleans the chain.
Skier
#39 Unread post by Skier »
VermilionX wrote:ok thanks...
Not really. You don't need a stand or centerstand for cleaning and lubing the chain. Matter of fact, I just got done cleaning my 599's chain and sprockets (both sprockets) without a stand. Granted it's more of a pain in the bum to do, but it's certainly cheaper than a set of stands. It was REALLY messy, stupid construction made my bike filthy.
I prefer a gallon container of diesel, an old toothbrush and some Simple Green for cleanup. Works great, cheaper than chain cleaner like Moose Sludge-Away and smells great. :D
VermilionX
#40 Unread post by VermilionX »
yes yes... i agree i need stands.
and that looks like a nifty product... sorry if i missed it but what's it called and got a link to a good price for it?
this is the stand i'll order...
$110 for both front and rear.
then i'll order this as well...
just kidding. :laughing:
