The clicking is usually the fuel pump
Theres a few things to check first. on the right side of the handlebars, there should be a kill switch, may sure its in the run position
Next make sure you haven't left it in gear. If its in gear, and the side stand is down, theres normally a microswitch that stops you starting it... (this is a good thing, its better to be on a bike when it starts moving, rather than stood next to it
After checking the obvious then start on the mechanicals...
If the battery was low, your headlights would be dim, so i suspect thats not it, but try anyway.
