Seized my 2 Stroke.
Tyrone ORourke
Seized my 2 Stroke.
#1 Unread post by Tyrone ORourke »
I suppose it had to happen with a 2 stroke, but its been a long time coming. Happened on the highway going 70mph. Luckily I heard the beginnings of the seize, so grabbed the clutch before it went solid. Was very pissed, as its a newly rebuilt and run in engine. Luckily no damage was done. Just to my confidence in the bike I suppose :(
rapidblue
#2 Unread post by rapidblue »
you seized it but no damage done????
confused
80 honda CB750F Super Sport
jonnythan
#3 Unread post by jonnythan »
rapidblue wrote:you seized it but no damage done????
confused
I believe the poster meant that no damage was done to him or to others or others' property.
Obviously the bike is damaged ;)
MakeCarsStandSTill
#4 Unread post by MakeCarsStandSTill »
Sounds like you need to take it apart again, someone didnt do something right
Live on the edge., Ride on the edge.
2006 Gsx-R1000(sold)
2006 Gsx-R750 (on its way)
flynrider
#5 Unread post by flynrider »
confused
Not necessarily. Back in the days when 2-stroke street bikes were common, it wasn't unusual to seize one up if you pushed it too hard. The usual fix was to pull over, let everything cool down, then continue on your way.
If you seize up a 4-stroke, then you've got real problems.
Bikin' John
'93 Honda CB750 Nighthawk
oldschoolorange
#6 Unread post by oldschoolorange »
look into your jetting if you were running a bit lean then it could get tight on you. I have seized 2 strokes before and then let them cool down and went on my way
83 GS550, 70 Yamaha CT1 175
ninja79
#7 Unread post by ninja79 »
what does "seize" mean?
I assume it's not the same as in "seize him!" :-)
Kal
Real Name: Jade
#8 Unread post by Kal »
confused
If memory serves the man has a Jawa/CZ...
They are awesome in a very weird kind of way.
Kal...
Relationship Squid...
GPZ500S, CB250N, GB250Clubman
t_bonee
#9 Unread post by t_bonee »
ninja79 wrote:what does "seize" mean?
It's when the piston stops moving in the cyclinder. Usually due to extreme heat or lack of oil. Or both.
A dog had his chain reduced one link at a time, every few days, until his chain was so short he could barely move. He never resisted because he was conditioned to the loss of his freedom slowly, over time. Are we in this country becoming like the dog?
#10 Unread post by BuzZz »
Go a little richer on the mainjet.
I agree with the others in that chances are it will be alright after it's cooled down. Just took a few thou of the life of it, is all.... :wink:
