removal vtwin ignition switch.
ofblong
Real Name: Ben
#1 Unread post by ofblong »
Ok so I put my bike up for the winter yesterday. Then I went to wally world to get a copy of my key made (only had 1 key). In the amount of time from when I was finished with my bike until I got to wally world I lost my 1 and only key jfakldjfkal;sdjfkasdl;jfkl;sdjasf;dfjas;.
anyways I called up my local stealer and they said I jsut need to bring the ignition switch in so they can get the number off of it. I have torn 1/2 of this bike apart trying to remove this dam switch. It has 2 rings on the backside that are not allen heads so I cant figure out how to remove those and on the front are some round bolts that are not normal bolts or allen heads so I dont know how to remove those. Any ideas from anyone? the ignition switch is on the side (I am assuming by ignition switch they mean the part you put your key in). I found a series of numbers/letters on the inside front cover of the switch which was very easy to remove that is that-xx but I dont know if that is the number they need or not.
96' Honda Shadow Deluxe VLX
CORSCO
#2 Unread post by CORSCO »
Those strange looking bolts you saw are broken bolts. They are designed to snap the head off once tightened so the ignition switch cannot be easily removed :wink: . They need to be drilled out to remove the switch.
The code they need should be on black electrical tape. Offhand I can't remember how many numbers it should be. Maybe a letter and four numbers?
#3 Unread post by Wrider »
OOHHH the irony! lol good luck with it!
ofblong
Real Name: Ben
#4 Unread post by ofblong »
hmm there was no tape anywhere on the thing with numbers. I forgot about this thread. I found my key when blowing the leaves. I figured it had fallen out of my pocket just outside of my garage but the leaves covered it up. so when I started blowing my leaves I found the key. Now to find the time to go get a copy made. Normally I leave the key on my key normal key chain except when riding. I dont need a big thing of keys flapping in the wind riding down the road :laughing: . I took the key off and hung it up on the key board in my house so I dont lose it again lol.
insaneman_12
Years Riding: 25
My Motorcycle: Motorcycle
#5 Unread post by insaneman_12 »
The numbers you saw are the right numbers. I know I make motorcycle keys.
71 CB 750 K1
94 PC 800
76 CB 550 K
75 TS 185
76 TC 185
63 YSA-1
06 YZ 450F
84 XL 350R
02 KX 85 with 75 XR 75 motor XR 200 sus.
ofblong
Real Name: Ben
#6 Unread post by ofblong »
insaneman_12 wrote:The numbers you saw are the right numbers. I know I make motorcycle keys.
hmm
well that sucks because that means its real easy for anyone to come up to my bike take a couple parts off and get my number to get a key made =[.
insaneman_12
Years Riding: 25
#7 Unread post by insaneman_12 »
there is a book that tell you the actual code from a list by matching the number you get off the ing. switch. Then you put the code into the machine. A little complicated lol
71 CB 750 K1
94 PC 800
76 CB 550 K
75 TS 185
76 TC 185
63 YSA-1
06 YZ 450F
84 XL 350R
