Spark I think
logitech104
#11 Unread post by logitech104 »
bad coil? sorry i'm stumped too. :(
insaneman_12
Years Riding: 25
My Motorcycle: Motorcycle
#12 Unread post by insaneman_12 »
I have a guss that the coil can be burning up the stators. I noticed at the end of the day it was an cdi coil. Im going to try and put on an AC coil and see if that works in the morning.
71 CB 750 K1
94 PC 800
76 CB 550 K
75 TS 185
76 TC 185
63 YSA-1
06 YZ 450F
84 XL 350R
02 KX 85 with 75 XR 75 motor XR 200 sus.
#13 Unread post by Sev »
insaneman_12 wrote:4 times :frusty: lol
It sounds like you've changed everything then... could it be buildup inside the cylinder head or something? This is making my brain hurt!
insaneman_12
Years Riding: 25
#14 Unread post by insaneman_12 »
Well it turned out that the coil was burning up the stators. Turns out that the CDI coils run off of DC voltage as the AC coils run off of AC voltage. Points are an AC current. There for the coil is not getting the proper amount of energy. Which causes weak spark. Just wanted to tell you in case anyone else runs into this problem.
71 CB 750 K1
94 PC 800
76 CB 550 K
75 TS 185
76 TC 185
63 YSA-1
06 YZ 450F
84 XL 350R
