fuel economy?
my mileage also depends of course on what kind of riding i do. most of the time its in traffic low gear high rpms and alot of stopping and going with alot of acceleration. usually short trips too wasting gas warming the bike up for longer than my actual ride time is really kills the mileage. cruising 6th gear with no stopping obviously sends the mileage through the roof.
doesnt help my bike has a stage 1 jet kit on it either.
03 katana 600
Thanks for the input guys. I figured the biggest reason was me getting used to working the throttle/clutch. We've all seen it, new riders tend to give it a little gas while creeping out the clutch. So I knew a good part of it is my riding. That's improving though and I noticed my second tank lasted longer than the first so there are signs of improvement.
i think the jet kit really killed my gas mileage ;\Chitlin wrote:I have a 2005 Suzuki Katana 600 and I am getting about 47 mpg in town. Haven't tested the mileage yet on the highway.
that and all the really short trips, i let the bike warm for 5 minutes or more then ride only 10 minutes. i went for a long ride last night on a full tank i rode almost 100miles and the fuel gauge didnt drop at all so i was happy with that at least.
03 katana 600
- Gummiente
- Years Riding: 38
True, but unless you're doing stop/starts every 50ft that isn't going to impact your gas mileage very much. The engine is new and, as others have already mentioned, it will use more fuel until things loosen up a bit. Then the mileage WILL improve.... as long as you refrain from jack rabbit starts, stoplight burnouts, full throttle acceleration tests, etc, etc.TheReaper wrote:We've all seen it, new riders tend to give it a little gas while creeping out the clutch..
Not that I'm accusing you of doing any of that - I'm just saying, ok? Chances are you took a different route at lower speeds with less traffic lights on your second tank of fuel, which would result in better fuel economy.
It isn't WHAT you ride,
It's THAT you ride
- allawybiker
- Telesque
- Legendary 500
Hold that clutch in on the down-hills!allawybiker wrote:Makes sense. I also think that because my area is hilly I won't get as good a mileage as I initially anticipated. Lots of stop signs, stop lights, slow traffic, and up/down hills!
-'95 Honda VT600CD / 'Shadow VLX Deluxe'
-'84 Ruestman WTF606
"[The four stroke] cycle is basically this -SUCK, SQUEEZE, BURN, and BLOW." -Dan's Motorcycle Repair Guide.
http://www.dansmc.com/MC_repaircourse.htm
That's actually illegal, but did do it once through the Rockies, since I was buying gas with change for 1000 miles. Thank god for Toyota's. Never would of made it otherwise. Rolling down a mountain on an interstate, going 100 mph in neutral, and left headlight out is not fun. Not that I'd know or anything.Telesque wrote:Hold that clutch in on the down-hills!allawybiker wrote:Makes sense. I also think that because my area is hilly I won't get as good a mileage as I initially anticipated. Lots of stop signs, stop lights, slow traffic, and up/down hills!
Brian
'03 Suzuki SV1000
'03 Suzuki SV1000
