jstark47 wrote:, I'm sorry, but this is just not accurate information. New Bonnevilles have extensive aftermarket support, and they are easy bikes to work on, due to the very basic design.
Depends on what pipes you get, and who does the work. Do your own research instead of depending on what the stealer tells you. .
I am not a mechanic. I am Mr. Badwrench. Actually, i am Mr. No-Wrench.
I had the dealer do a stage-1 with screaming eagle pipes and AC. The stage 1 done at the stealer for my 1200R was cheaper than the stage one for a t-100 at the Triumph dealer. That is a fact.
If I did the stage 1 myself, with aftermarket products, I could've done it even cheaper. Slipons and an AC for a sportster is pretty darn cheap. I have no idea the cheapest Bonnie parts, although if I recall correctly they were more expensive on the Bonnie forums I looked at when I was trying to buy the t-100.
How many types of aftermarket pipes are there for the bonnie? I can tell you that there are a HUGE number for the sportsters.
As far as working on them, heck triumphs may be easier...I can't tell you.
But let me put it this way:
Let's say you and I go on a road trip all over the US. And let's say that we both break the same part and neither of us have a replacement and can't fix it.
Who is going to be able to get a replacement part quicker, and get it fixed out in the middle of nowhere, with no access to an online forum?
Let's try to add up the HD dealerships and indy shops that work on and carry stock and aftermarket parts for HD and lets add up all the Triumph dealerships and indy shops that carry and have in stock Triumph parts and work on them.
So in MY opinion, I think that parts (both aftermarket and OEM) would be easier and cheaper for the sporty, simply due to the number of sporties on the road in the US.
I'm skeptical: I want to see someone with an 883 Harley get 51 MPG in real life mixed riding. I've hit 50 MPG on my Bonneville, but that was on an all-highway trip
Yeah, that surprised me too.
My point is that the 1200R, even though it's 100 lbs heavier, gets very similar mileage to the t-100.
