oil to gas ratio
rapidblue
oil to gas ratio
#1 Unread post by rapidblue »
my oil injector doesnt work and I was jsut wondering what the correct mix would be for a two stroke
does 5 ounces to a gallow sound about right?
Psyco Diver 69
#2 Unread post by Psyco Diver 69 »
Wha type of bike, I use a 32:1 in my dirtbike and brother uses a 50:1 I think in his CR 125
Jake 20/m
1980 Honda CB750 Custom
1972 Oldsmobile 442
1985 Oldsmobile Cutlass Supreme
Telesque
#3 Unread post by Telesque »
Maybe you ought just get your injector fixed? :)
(Ooh, and hey, Psycho! I used to own an '81 Cutlass Supreme with a transplanted 427 Cadillac engine. :twisted:)
-'95 Honda VT600CD / 'Shadow VLX Deluxe'
-'84 Ruestman WTF606
"[The four stroke] cycle is basically this -SUCK, SQUEEZE, BURN, and BLOW." -Dan's Motorcycle Repair Guide.
http://www.dansmc.com/MC_repaircourse.htm
Psyco Diver 69
#4 Unread post by Psyco Diver 69 »
Telesque wrote:Maybe you ought just get your injector fixed? :)
Injector parts are almost impossible to find anymore, I think Honda is the only company still making those parts and even they are phasing them out. You might be able to find something used on ebay, but I just say convert it to premix its easier in the long run, esspecially if your out riding all day and your injecter freezes causing your motor to sieze up.
(Telesque, sounds like a pretty wild combination you had there)
Jake 20/m
1972 Oldsmobile 442
rapidblue
#5 Unread post by rapidblue »
Pretty much my thoughts, there is no way I'll every find and injector for that bike, i couldnt even find an exhaust gasket
so I just nee to know what ratio so that I dont cause problems
80 honda CB750F Super Sport
emperorjordan
#6 Unread post by emperorjordan »
we use 32:1 in my friends CR 250.... have you tried googleing ratios for your bike?
-2005 Suzuki DRZ-400S (The Fast Color).
- FMF Power Core 4
- 3x3" Air Box Mod, DynoJet Kit
- Dunlop D606 Tires
When I die, I want to die like my grandfather--who died peacefully in his sleep. Not screaming like all the passengers in his car
