Correct, and that's usually caused by a lack of power going through the relay. Get a buddy to hold a multimeter to the battery terminals as you crank it. I'll bet good money the voltage will drop like a rock when you hit that starter.Sev wrote:That clicking noise is the solenoid/starter relay attempting to do something.
I'd wager the battery is toast, but make sure the connections aren't corroded first!
