1. when you're on a road with lots of curves and you move continually from left to right and right to left?
2. when you bend down so much your knee touches the ground as in a race?
asd wrote:1. when you're on a road with lots of curves and you move continually from left to right and right to left?
I always follow the rules.
The only exception to the rule occurs when I make an exception to the rule not to make an exception to the rule and that only occurs under exceptional circumstances.
