Removing plugs over air mixture screw.
norsseman
Location: In the Country. Far back in the deep dark woods. Geiger Heights, Washington
#1 Unread post by norsseman »
I will be removing the small plugs over the air mixture screw on my Vulcan 750, and would like to know the best way to get those little buggers off? I've heard that some riders use a drill, but I would rather
use something else if possible?
Freedom is not Free
#2 Unread post by Johnj »
I guess you could try a small drift or punch and a hammer, but I think the best method is to drill a small hole and start a screw into it. Now grab the screw with your pliers and give it a tug.
Damian
Years Riding: 5
My Motorcycle: 1994/Honda/Magna
#3 Unread post by Damian »
Johnj wrote:I guess you could try a small drift or punch and a hammer, but I think the best method is to drill a small hole and start a screw into it. Now grab the screw with your pliers and give it a tug.
Yeah, that's the best technique I've found. Just be sure not to drill too deep, you only need to get through the cap. The screws below are usually pretty soft, if you bump them with the drill, you might damage them.
1994 Suzuki Katana 600
1994 Honda Magna 750
