So I just bought my first bike- 1986 Yamaha Radian and I am very excited of course. I rode it around the block about 3 times and then stalled at a stop sign. Now when I turn the key to ON, the headlight won't turn on and I can't start the bike. I had to walk it back over to my place. Not what I expected of my first ride. The bike only has 5900 miles on it and I was told has had all normal srvce done recently including oil, carbs, sparks, and new tires. I was also told it has a new battery and drove beautifully from the guy's place I bought if from to my place (12 mi).
What's the deal? Is it the battery or is the battery not getting charged?
HELP!!
My bike won't turn on; I just bought it!!
- Tricycle Squid
- Veteran
- Sev
Put it back in neutral and try again. More then likely the kickstand lockout switch is still engaged. It will kill the engine if:
1) you put it in gear with the kickstand down
2) you try to start in gear with the kickstand down
