How to replace kill switch?
- intotherain
- My Motorcycle: FZ6
My kill switch does not work and I think it's because I cut a wire while I was replacing my speedo.
I see kits everywhere but I can't see any manuals or instructions on where the wires attach..
- intotherain
- intotherain
- Johnj
- Real Name: Johnny Strabler
Dohan, go to the auto parts store and get some but end connectors. You also need a crimp tool for the but end connectors. Strip about 1/4 inch of insulation from the wire, place the connector over the wire and crimp it to the wire. do the same to the other piece of the wire to connect them together.
- Sev
How did you lose the other two ends?
And why would you cut them in the first place?
Any "new" switch that you buy is going to require that you hook it into where the old one was. So you're going to have to find the old wires anyways... might as well start looking for them now. And no we can't tell you where they end up, other then they wander into the wiring harness at some point.
- intotherain
Well that didn't work. I crimped together the two cut wires but nothing worked! I went back to the beginning and I cut all four wires coming out of the electric starter/kill switch buttons. I found out that two wires are for the ignition and two are not. I tried crimping together almost every possibility and to my dismay, none of them activate the kill switch! Ahhh Im so frustrated! Any suggestions?
- Sev
So... you found the ends that you cut... and crimped them back together?
What did you use to crimp them? And did you strip the wires first so that you could make a connection across the wire itself and not the insulation?
