I got Bad Gas in the Tank, and now engine wouldn't crank
- TheWolfClan
Second value is there
The Second value you're talking about is present on the value but nothing is attached to it
- Sev
it keeps replacing something on there with "value" but... if there is indeed a second spot to hook a hose, you need to hook up or find the vacuum line that should go to it. Otherwise you're never getting gas outta that tank. Start looking for loose lines.
