Clutch Problem????
Clutch Problem????
I have a 2002 Suzuki GSXR750. I came through a corner by my house and released the clutch handle and it acted like it was in neutral. I did pull the cover to the clutch and the plates look burn but the oil level was fine. Any ideas?????
2002 Suzuki GSXR 750
- Sev
If the plates look burned... you need to replace them.
Have you been slipping your clutch overmuch? Or clutching up into wheelies?
You'll also need to check to see if the metal discs have either warped or blued. Best done by a shop.[/b]
- Sev
if the metal plates look blue you're going to need new plates, and new fiber discs. You're also going to need to make sure that they stack to the same height as the old stuff.
Then you need to check your clutch basket and clutch hub for wear. The "fingers" should be un notched and smooth.
new problem
They shipped my new clutch USPS instead of UPS 2DAY AIR like I paid for
but..... I email them and they are going to refund the 22 dollars for the air fees
and I should see it in 2-3 days "they say" Question??? What weight oil is being used in your bikes and does anyone know how much oil it takes to fill a 2002 GSXR 750?????
- Regular
