2003 1100 VSTAR, what to look for?
jetmech727
#1 Unread post by jetmech727 »
I'm goignt to have a look at an 03 1100 VSTAR tommorow. Just wanted to know what I should be looking for in terms of things to be concerned about.
Thanks
big_ry_ry
Years Riding: 19
My Motorcycle: 2007 yamaha VStar 1100 classic
#2 Unread post by big_ry_ry »
see if it has an oil relocation kit, look at the battery, they are pretty much the same from the early 2000;s through the 07's. Look for meat on the front pads as they wear a little quick. If it has floor boards check to make sure they are not damaged or cracked underneath. Some people try to modify the front light bar and put the passing lights on the stock bar, make sure the front turn light bar is not cracked..
Usual stuff like tires are good, brakes, fluids, runs and idle's good. Check the pipes for discoloration as this bike may need a jet kit if one was not installed properly or installed at all witth the aftermarket pipes...
All i can think of right now hope this helps!
