I have a 1981 Honda CM400e that I've owned for 6 years. It has spent most of it's time in my garage but it ALWAYS started right up no matter how long it sat.
Cliff Note Version:
Ugly Divorce / Satan's Sister put dirt in the gas tank and I ran the bike about 5 minutes before I thought to check for sand (after 10 years of marriage you get to know a person).
I pulled the tank and cleaned it out ... she actually grabbed dirt (mostly small pebbles that wouldn't fit through the gas line) and when I drained the oil there wasn't any signs of grit or anything to make me think the dirt actually got into the carb BUT I pulled it and cleaned it just to be safe ... seemed fine.
The bike fired right up, idled a little rough but I figured it just needed to work out some creeks. When I pulled it out of the garage into the darkness I noticed that the left pipe was CHERRY RED. I shut the bike down and let things cool off. The right pipe wasn't hot at all.
I am NOT a mechanic (but I have stayed at a Holiday Inn Express) but I figured the best way to learn is to dive right in ...
I pulled the plugs and put my thumb over the hole when I turned it over. There was enough compression to kick my thumb off on both sides. I know that's not the ideal compression test ... but at least it gave me a start.
Next I pulled the pipes to see what was happening in that neighborhood ... left side HOT right side COLD (no surprise there) and I would get flames out of the LEFT SIDE only when I released the throttle.
I went back to the carbs and cleaned them again (because they are so much fun to get off the bike) and tore them right down. Put everything back together and guess what? Left side HOT right side cold. So to narrow down my uneducated guesses even more I poured a little gas into the right spark hole, replaced the plug and turned her over. BOTH sides sounded GREAT for about 3 seconds ... then of course the gas was gone from the right side and I'm back to left hot right cold.
So I am guessing (again I am no mechanic) it's got to be a fuel issue on the right hand side. I am getting fuel into the right side bowl but I am guessing that's as far as it's going.
NOW, when I was putting the carb back on I noticed that one of the throttle cables was busted (pulled it right out of the sleeve ... rusted away). It's not the one that REVS (or opens the carbs) that cable is working just fine and the throttle does return to "idle position" by itself ... so I'm not sure what that cable actually did/does.
Any thoughts? Tips? How To's? Prayers???
Thanks!
