1999 VT 1100 Shadow Aero
insaneman_12
Years Riding: 25
My Motorcycle: Motorcycle
#1 Unread post by insaneman_12 »
This is one for the experts out there. As the bikes rpm get high the thing looses power then gets it back. Basically it goes a sec. on and a sec. off. This continues untill you drop the rpms. I dont think it is hitting the rev limiter, but im not for sure. Any one else run into this prob. If so WTF.
71 CB 750 K1
94 PC 800
76 CB 550 K
75 TS 185
76 TC 185
63 YSA-1
06 YZ 450F
84 XL 350R
02 KX 85 with 75 XR 75 motor XR 200 sus.
jonnythan
Re: 1999 VT 1100 Shadow Aero
#2 Unread post by jonnythan »
insaneman_12 wrote:This is one for the experts out there. As the bikes rpm get high the thing looses power then gets it back. Basically it goes a sec. on and a sec. off. This continues untill you drop the rpms. I dont think it is hitting the rev limiter, but im not for sure. Any one else run into this prob. If so WTF.
All gears, or just the highest gear?
What speed does it happen at?
insaneman_12
Years Riding: 25
#3 Unread post by insaneman_12 »
All gears just at high rpms. Im almost thinking fuel pump or fuel filter. Or even vaccume lines, but I dont have a whole lot of time to spend on it. I am trying to figure out some ideas before I get to this bike. I still have about three more bikes to fix before I get there. All I know is I put in new sparkplugs and the air filter has about 20 mi on it, but the problem is still there. My boss loves to rush me and I hate it lol.
71 CB 750 K1
94 PC 800
76 CB 550 K
75 TS 185
76 TC 185
63 YSA-1
06 YZ 450F
84 XL 350R
#4 Unread post by Sev »
Check to see if your air filter is clean.
Then Check your fuel filter - probably inside the gas tank.
Then Check to make sure your fuel line isn't kinked.
If that doesn't solve the problem I'd pull apart the carbs and give them a good cleaning. And if that doesn't work I'd start testing the ignition coils, and ignition circuitry.
But it sounds like inconsistant fueling to me.
insaneman_12
Years Riding: 25
#5 Unread post by insaneman_12 »
Im also trying to find the gear ratio for the trans on this bike if anyone knows it. I truly belive the rev limiter is kicking in, but I have to be able to prove it to my boss because he does not belive me :frusty:
71 CB 750 K1
94 PC 800
76 CB 550 K
75 TS 185
76 TC 185
63 YSA-1
06 YZ 450F
84 XL 350R
