Hmmm... I always thought mine vibrated rather happily. It never seems to be depressed; it always starts first try and takes me everywhere I want to go and back again. My old BSA, well, it vibrated rather malevolently. My Triumph Thunderbird triple buzzed along contentedly for the most part, but my Triumph Tiger triple vibrated like a hyperactive 5yr old at the high end of the rpm scale. My Kawasaki Drifter 1500 had a bit of a lumpy (and noisy) idle, but it smoothed out at speed... although not as much as my Electra-Glide and nowhere near as much as my Road Glide. My Ural, well, let's just say that I singlehandedly support the blue Loc-Tite industry with that bike.Sev wrote:It is in the nature of a V-twin to vibrate sadly.
Best V-Twin for power without vibration?
- Gummiente
- Years Riding: 38
It isn't WHAT you ride,
It's THAT you ride
It's THAT you ride
- Gummiente
- Years Riding: 38
That varies from bike to bike. Inline three and four cylinder motors tend to produce high frequency vibrations that are normally felt in the handlebars and footpegs (ie: buzziness") and seen on the mirrors. V-Twins tend to put out low frequency pulses that are felt through the seat, handlebars and footpegs - but the vibrations are different than that of the 3 or 4 cylinder motors.blues2cruise wrote:Where exactly does everyone feel the vibrations? And is it only when you're running at top speed or at high rpm's or what?
I was a passenger on a friend's older Harley and the vibrations through the floorboards were awful. I sure don't feel that on my V-Star.
With the V-Twin, a couple of methods are used to reduce the amount of vibes. Some manufacturers use counterbalancers that rotate inside the engine, but opposite in direction, to counteract the power pulses. Some manufacturers use rubber mounts to isolate the motor's vibes from being transmitted through the frame.
Your friend's older Harley has very little, if any, compensating measures for vibes (especially if it's an older Shovelhead) and definitely none in the passenger area. The older Touring family of Harleys had rubber mounted handlebars and (usually) rubber mounted floorboards to somewhat offset the pulses from the rigid mount motor. Newer Harleys like mine have all that plus the rubber motor mounts, which all do a very effective job of minimising discomfort.
It's THAT you ride
It's THAT you ride
- Sev
I'm sending you a bill for the moniter I just sprayed coke onGummiente wrote:Hmmm... I always thought mine vibrated rather happily. It never seems to be depressed; it always starts first try and takes me everywhere I want to go and back again. My old BSA, well, it vibrated rather malevolently. My Triumph Thunderbird triple buzzed along contentedly for the most part, but my Triumph Tiger triple vibrated like a hyperactive 5yr old at the high end of the rpm scale. My Kawasaki Drifter 1500 had a bit of a lumpy (and noisy) idle, but it smoothed out at speed... although not as much as my Electra-Glide and nowhere near as much as my Road Glide. My Ural, well, let's just say that I singlehandedly support the blue Loc-Tite industry with that bike.Sev wrote:It is in the nature of a V-twin to vibrate sadly.
Well, it looks like Im a little behind on this one.
Oh well. Hopefully this will Help.
Kawasaki VN1600 classic.
I suppose the meanstreak and Nomad would be the same. Dont know for sure though. Never ridden one.
I have a bad hand due to an accident that happened about 15 or so yrs ago.
I quit riding because I didnt think I could handle the vibes of a bike. A year ago I got back into it. I got a 900. A couple months ago I traded it in for the 16. The 9 had some vibes that bugged me a bit, but the 16 is as smooth as silk.
Kawi VN1600
I dont give a damn what the name on the bike is..........Just ride it.
AZRider: Never met a bike he didnt like.
